Shorty antenna? - JeepForum.com
post #1 of 4 Old 09-01-2013, 03:15 PM Thread Starter
daven75
Shorty antenna?
Anyone know where I can get a shorty antenna from!? I've tried autozone and walmart and none of the ones they have worked. all the wrong screw. Itd be for a factory replacement on a 2000 xj.
daven75 is offline
post #2 of 4 Old 09-03-2013, 04:53 PM
DriverX
Metal mast or flexible rubber? I have the short rubber one that I picked up from WalMart. No adapter used, it screws right on to the factory stud.
DriverX is offline
post #3 of 4 Old 09-03-2013, 06:52 PM
dmill89
1995 XJ Cherokee
Most antennas with GM threads will work (I don't have a shorty but I did have to replace the original whip). I found this out the hard way after trying all the Chrysler adaptors but none fit, however the antenna with no adaptor (GM threads are standard in most aftermarket antennas including the one I used, adaptors are usually used for other brands) worked fine. Remember the XJ was designed by AMC who was reaching into everybody's parts bin so not everything is Chrysler standard.
dmill89 is offline
post #4 of 4 Old 09-03-2013, 06:55 PM
JacoToTheB
On my mustang I just took the ball off the top of the antenna then cut it to the length I wanted then put the ball back on that. I always use my iPod through the stereo so idk how much it affected radio reception.
'97 ZJ
K&N drop-in & Slow
F150 F>R (The link below because I couldn't figure out how to hyperlink...)
http://www.jeepforum.com/forum/f13/my-jeep-build-infamous-f150-coils-1767489/
JacoToTheB is offline
