Shall I weld with gas tank on? - JeepForum.com
post #1 of 11 Old 07-05-2009, 06:43 AM Thread Starter
fangt
Last night I was bored, so I went under my XJ to check all the bolts and grease the joints. I found out that upper shock mount on my rear right shock broke off the body. I decided to weld it back on, but I am a super beginner welder, I only know MIG welding and have never weld facing up. any tips and pointers?
Also, I heard that I need to remove the gas tank when I weld on my vehicle. Is it absolutely necessary? If not, what shall I do to make it safer?
Thanks.
2007 Jeep Wrangler Unlimited Sahara Black, bone stock.
(Wife's now)
2000 Jeep Cherokee Sport Chick Shiit Green.
3.5 RE Superflex, 31/10.5/R15, SYE, New CV driveshaft.
fangt is offline
post #2 of 11 Old 07-05-2009, 07:12 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Have someone there with you and weld away. Just make sure you don't smell and gas fumes and have a fire extinguisher or hose ready before ou start.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #3 of 11 Old 07-05-2009, 07:35 AM
little_Jeep
I tore my upper control arm bracket on the driver's side frame off. If you look at this, you will see that you fuel lines are about 1 inch away. I paid to have a guy weld it because I wasn't feeling warm & fuzzy about doing it. The guy welded it without even giving it a second thought. I say, make sure no fuel leaks, know where you wand is pointing & weld away.
little_Jeep is offline
post #4 of 11 Old 07-05-2009, 09:08 AM
littleblackXj
1993 XJ Cherokee
If you are really worried about it, throw a wet rag over the parts you don't want to catch on fire
1993 Jeep Cherokee
Rubicon Express 4.5" Lift
33" Wrangler Duratracs
30/44 4.88s Disks all around
Rear Detroit/Open front
littleblackXj is offline
post #5 of 11 Old 07-05-2009, 09:15 AM
StaleAle
Disconnect your battery before you weld anything to your jeep so you don't take a chance of frying the CPU. Also be smart. If there is the slightest chance that you could start a fire by being to close to the gas lines or tank then you should take every precaution you can before you start.
StaleAle is offline
post #6 of 11 Old 07-05-2009, 09:16 AM
GregB_00XJ
My mechanic (and a good friend) welded in a set of upper BPE's in the rear (same spot as you) with the tank on...no second thoughts about it.
I think that as mentioned, you should have a friend there with a fire extinguisher, and you will be good to go. If you have gas leaking out of your tank, you run the risk of going BOOM every day!
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #7 of 11 Old 07-05-2009, 11:27 AM
m2rtin
When you weld with MIG, there is gass comming out of the pistol head, that prevents catching fire...but the temperatures are great in deed...
When you weld, you should have the alternator disconnected!
edit: the gass tank on should be ok, if it's not leaking badly
m2rtin is offline
post #8 of 11 Old 07-05-2009, 12:56 PM Thread Starter
fangt
Just did it with gas tank on, thanks for all the advices. I got my buddy stand by with fire extinguisher. Everything went well. Only problem is that my weld sucks.. I blasted the metal all over the place, hope the weld will hold.
(Wife's now)
fangt is offline
post #9 of 11 Old 07-05-2009, 04:15 PM
m2rtin
that happens, you have to keep the head of the pistol realy close to the welding, so that the CO2 can prevent oxidation of the weld, also the weldings are nicer if you lick them a bit with a grinding wheel...(I don't know the exact terms...sorry), keep practising, and a skill will sort itself out
m2rtin is offline
post #10 of 11 Old 07-06-2009, 10:46 AM
XJH-007
XJH-007's Avatar
You welded your shocks to the Uni-body??
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #11 of 11 Old 07-06-2009, 11:24 AM
little_Jeep
Naw.......... he broke the upper bolts and is just going to tack weld a couple small bolts in place to act as studs for the upper shouck mount.
Spot Weld vs. Continuous Weld on Floor Pan... Gnl.Weirdness XJ Cherokee Technical Forum 49 02-14-2010 08:45 PM
AXLES: Too Weld, or Not Too Weld... JohnFM3 XJ Cherokee Technical Forum 29 12-05-2007 07:55 AM
Weld or No Weld Rear Dif. Green97Cherokee XJ Cherokee Technical Forum 14 01-12-2007 09:07 AM
shackle help, to weld or not to weld swebilius75 XJ Cherokee Technical Forum 2 10-11-2006 11:33 AM
Rear BPE: to weld or not to weld... midfat XJ Cherokee Technical Forum 18 04-13-2006 04:53 AM
