08-17-2010, 09:29 PM
#1
Is your stock leaf springs sagging? I am told the stock distance from the center of the wheel to the bottom of the fender is 17". With no load I have 16.5". At what point is a AAL a waste of money and time? If I add a 2" aal will I get 2" from stock or the existing height?
08-17-2010, 10:00 PM
#2
2" from existing height, if that. you could do an AAL, but you would be better off with a bastard pack.
Hello, I noticed you have an XJ. I have an XJ as well, would you perhaps like to go wheeling?
08-17-2010, 10:40 PM
#3
Do aal and if it sags add a 1 inch block
[CENTER][B][COLOR="Black"]1961 CJ5 F134 restoration[/COLOR][/B][/CENTER]
[CENTER][COLOR="Green"]1996 XJ 5 Speed, 100% Herculined, Rough country 4.5, BFG A/T 33's[/COLOR][/CENTER]
[CENTER][COLOR="Blue"]1999 XJ Classic, Auto, Power everything, stock for now[/COLOR][/CENTER]
[COLOR="DarkGreen"][CENTER]01 GSX-R 750, power commander, much more[/CENTER][/COLOR]
[CENTER][COLOR="Blue"]2002 Honda Civic 5 Speed Coupe, 130k[/COLOR][/CENTER]
[CENTER][URL="http://www.jeepforum.com/forum/f22/marks-highschool-build-slow-1068542/"][COLOR="Red"]96' Build[/COLOR][/URL][/CENTER]
[CENTER][B][COLOR="Red"]S[/COLOR][COLOR="White"]E[/COLOR][COLOR="Blue"]M[/COLOR][COLOR="Red"]P[/COLOR][COLOR="White"]E[/COLOR][COLOR="Blue"]R[/COLOR] [COLOR="Red"]F[/COLOR][COLOR="White"]I[/COLOR][COLOR="Blue"]D[/COLOR][COLOR="Red"]E[/COLOR][COLOR="White"]L[/COLOR][COLOR="Blue"]I[/COLOR][COLOR="Red"]S[/COLOR][/B][/CENTER]
08-18-2010, 12:02 AM
#4
how much are blocks?
2000 XJ sport 4.5 inch Rough Country Series X lift Cooper Discover M+S 31X10.5 15x8 uniques Dana 30 front Chrysler 8.25 rear Stock gears
Colorado jeep club member #1992
http://www.jeepforum.com/forum/f22/patriot-blue-build-1179435/#post11126000
08-18-2010, 02:05 AM
#5
? An AAL will get you 2" over stock. I've got a 94 with a 2.5" AAL sitting in between the stock springs with 1.5" shackles, and it certainly gave me what it was advertised. I would only recommend running it until it sags, which probably won't be super long, but it's a cheap fix.
08-18-2010, 09:23 AM
#6
I wouldnt waste money on an AAL
You can buy a set of S10 springs (or another set of XJ springs) and put them with your springs making a bastard pack, that way with used springs they have already lost most of their temper (allready bropken in) and wont sag much from where you get it at.
Do a search for bastard pack, and read up on it.
I bought a second set of XJ springs and added to my springs I got 3" (and a very comfortable ride)
I would not recogmend blocks, but shackles are a good option and they will give you a better angle also
95' XJ Country - Stock Skids - Limited Slip Rear Diff
Off Road Package - 4.0 HO - AX15 - NP231
Repeal Ohms Law!!!
Originally Posted by Azzy
You can tell the character of a person in how they treat someone who can do nothing for them.
08-18-2010, 01:28 PM
#7
i would buy HD leafs from quad. and do a budget boost. i would say from rough country lol
2000 XJ
08-18-2010, 03:17 PM
#8
my stock springs sagged a ton.....i was down to like 15.5" between the center of the wheel and the flare, it was bad and because i do a lot of lugging around heavy stuff and towing on the farm i picked up another set of XJ springs and made a bastard pack.....i cut the eyes off the second set of mains and mixed all the springs except for 1 set of the 4th (littlest) springs, so i went from 4 leaves per side to 7.....it has way more carrying capacity and put me 1.5-2" overstock height......AAL's put you over your existing height, not stock and will sag over time.....after using a 3" AAL on my brothers XJ and now after 3 years having it be only about 1.5" over stock i wouldnt use one again
here is mine with the bastard pack on 235/75/15's
08-18-2010, 10:44 PM
#9
15 bucks for a set of 2 and a few bucks for new ubolts. Probably 30 bucks total
08-19-2010, 03:52 AM
#10
Here's mine sitting on 2.5" AAL and 1.5" rear shackle, used with stock leaves from 94. I knew it wasn't a permanent solution, but it definitely got the job done for now. Fits 32's comfortably with stock flares - although I plan to trim soon.
I definitely wouldn't recommend AAL as a permanent solution - in fact, before this kit I was really anti-AAL; however, I've been pretty impressed with how it did. Once that baby starts goin, though - I'm upgrading to full leaves, and probably stepping it up to 5" while I'm at it
