Rubicon 3.5 super ride lift - JeepForum.com
post #1 of 3 Old 10-09-2013, 08:45 PM Thread Starter
brak876
I plan on buying this lift on friday http://www.quadratec.com/products/16300_818.htm and running it with no other mods with 31x10.5/15 stock rims atm...Anything I should know? I have a transfer case drop kit but not sure if i'll need it. I've read so many posts saying i don't need a SYE but has anyone ran this setup? Or used this lift?
brak876 is offline
post #2 of 3 Old 10-10-2013, 07:30 AM
xjkid98
I'm going to be running this lift also I just ordered one, except I bought the aal version. Stock wheels and 30" bfgs. No other mods as of the moment. I might end up doing a HnT SYE and a front shaft from another xj.
xjkid98 is offline
post #3 of 3 Old 10-10-2013, 08:49 AM
Maxxrus08
1992 XJ Cherokee
At 3.5" you should be fine. I got the 4.5" Super flex lift and it came with a 3/4" TC drop. I also had to put in axle shims in the rear to help out the pinion angle but have had no problems with it on or off road. RE makes a great lift and easy to install. The only thing i would suggest is look into a set of wheels with a 3.75" or 4" back spacing. they will help give you a more width and make it possible to run a wider tire so you dont rub on the LCA.
1992 Jeep Cherokee Lerado 4x4
4.0L HO Auto Trans
RE 4.5" Superflex lift
33x12.25x15 BFG KM2
Maxxrus08 is offline
