Rough Country Lifetime Warranty? - JeepForum.com
post #1 of 6 Old 09-07-2012, 07:04 PM Thread Starter
lilseth0014
1997 XJ Cherokee
So have had my lift for 5 years. Lower adjustable control arm decided to break. Threads stripped out. Anyways part should be covered under the warranty. Call them up an they say " oh sorry that part was discontinued 4 years ago. We can't warranty that because we can't give you the same part." WTF? i asked to speak with a manager an demanded a part that would do that same job as my old control arm. Its not my fault you discontinued the part. He said all he could do was give me control arm ar cost. which is still 95 bucks. Any way i could get around this. From everything i read they should warranty the product no matter what. It doesn't state anywhere about discontinued parts not being covered. Any input on this matter is greatly appreciated.
lilseth0014 is offline
post #2 of 6 Old 09-07-2012, 07:07 PM
BriansCJ
1994 XJ Cherokee
Ask for your $$ back
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #3 of 6 Old 09-07-2012, 08:47 PM
whitexj98
You called rough coutry directley correct? I would call again and Direct them to thier warrenty page...
http://www.roughcountry.com/warranty/
There is a guy on NAXJA, Jason he works for rough country, Dont know if hes on here but I bet he could help.
Im feeling hepful tonght....> http://www.naxja.org/forum/member.php?u=20493
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #4 of 6 Old 09-10-2012, 10:23 AM
AmbuGrl
AmbuGrl's Avatar
We have a rough country rep in the vendor section. I believe his name is Ryan
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #5 of 6 Old 09-15-2012, 10:02 PM
JrTjK
1978 FSJ Wagoneer
Was the lifetime warranty stated back when you bought it or was this a more recent policy change? I know most people don't keep all their receipts, but if you still have it, check to see what it states. If not, 5 years is a long time and I'd bet they don't keep records that long so have no proof you bought it new.
It's hard to say something is a manufacturing defect after 5 years of use unless you often checked to make sure everything was torqued to spec.
I'm not trying to say it's your fault, but I can understand why they don't give away sets at someone's word over the phone without you providing more info. Good luck, though.
JrTjK is offline
post #6 of 6 Old 09-16-2012, 12:48 AM
rugsucka
Threads stripped out sounds like wear and tear, not defect.
Did you wire wheel the heck out of them and apply lubricant before adjusting? - self induced.
Did you have adequate thread engagement? - self induced.
Did you torque the jam nut and use locktite to hold it fast and prevent wallowing? -self induced.
I would imagine cracked welds would be the only thing they would warranty long term based on the typical use of a lift kit on a jeep. I don't know the details of the RC warranty, but if it isn't a "what ever happens, even if it's from abuse" warranty you're probably stuck. Cost for adjustable arms is not the worst, or move up to a bomb proof warranty type vendor with a reputation for better parts. That's gonna be much more than 95 bucks.
Pro-rated your arms only cost you 19 bucks a year for the use you got out of them. I'll bet you won't wear the next ones out before the body turns to powder.
rugsucka is offline
rough country lift versus tuff country lift otownxj XJ Cherokee Technical Forum 17 07-12-2014 10:15 AM
Rough Country forever rough? squirlgod XJ Cherokee Technical Forum 15 03-02-2012 02:16 AM
Rough Country AUSHii XJ/MJ Cherokee Non-Technical Forum 1 07-11-2010 10:22 PM
Rough Country TimA XJ Cherokee Technical Forum 6 06-17-2008 02:51 PM
Chrysler announces lifetime powertrain warranty! 330LICIOUS XJ Cherokee Technical Forum 4 07-27-2007 03:00 PM
