Replacing floor pans - JeepForum.com
post #1 of 6 Old 07-20-2013, 04:04 PM Thread Starter
1995_XJ
1995 XJ Cherokee
I need to replace the floor pans, and rockers. I only ripped up the carpet in the cargo area, which did not seem to bad but had some holes ones I took a wire brush to it.
Here it is
Pretty much where ever you seen rust became a hole. So for now my only idea was to seal and paint it until I could replace them. I'm sure the rest is the same way if not worse
My problem is, I do not have a welder and can not weld. So doing it myself is out for now. Now, this is assuming that the transmission hump is still good and all I need is replacement pans not the whole floor. If I would get all the pans, what would you estimate a shop charging to weld them in for me? I really don't even know a shop around me that does that kind of work to get a estimate.
1995 Cherokee Sport
1995_XJ is offline
post #2 of 6 Old 07-20-2013, 04:29 PM
dmill89
1995 XJ Cherokee
Find a good local body shop to get an estimate, they'll usually do this kind of work. Since it is mostly labor prices will vary significantly, if all pans need replaced I'd expect something in the $2000-3000 range, more if labor rates are high in your area. The rust doesn't look too bad (of course pics can be deceiving), if they can just patch some holes/areas without replacing the whole pans it should be cheaper.
I'd start by pulling the rest of the carpet to get an idea how bad/widespread the damage is. XJs can be weird, sometimes all pans are equally rusted, sometimes one pan is rusted and the others are fine.
dmill89 is offline
post #3 of 6 Old 07-20-2013, 05:28 PM
Motorcharge
Cut out the rot and buy replacement pans online and have someone local weld them. Body shop is the last place I'd have it done unless money isnt an issue. Even if you cant get it welded you can overlap it and secure it with self tapping screws and caulk the seams. PO did it on mine and you can barely tell.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 6 Old 07-21-2013, 09:47 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I'd assume JBWeld would work for this application as well?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #5 of 6 Old 07-21-2013, 11:12 AM
dmill89
1995 XJ Cherokee
If you go the epoxy route PC7 works better for body panels, floor pans, or just about any sheet metal.
dmill89 is offline
post #6 of 6 Old 07-21-2013, 11:13 AM
Motorcharge
It might.
I was going to undo the PO's work and actually weld them up, but I haven't had a problem yet from it so I haven't bothered.
|SOLD|
| June 2015 COTM |
