Replacement Fender Liners - JeepForum.com
post #1 of 3 Old 10-01-2014, 06:34 PM Thread Starter
OldNewJeeper
I am not sure if this is the correct forum so please be patient.
As you might deduce from my other post, I have been speeding a few hours under my 99 Jeep Cherokee and discovered a couple of things. A fairly minor but potentially important thing is that at some time in the past, someone has cut a significant amount of the liner away. Not so much as to allow mud to get under the fender but water will now have direct access to the body cavity under the door. This is true for both driver and passenger front wheel wells. Unfortunately I have not found a supplier for these liners. I have found my local used parts suppliers to be rather unreliable.
Any suggestions?
OldNewJeeper is offline
post #2 of 3 Old 10-01-2014, 07:46 PM
Spokes
if your fenders are cut its pretty hard to mount them inside. SOOOO.... this is what i would do...
1) call junkyards.
2) put a pool noodle in the door... what i do and it works awesome
3) ignore it haha
hope this helps. if you want more info on the pool noodle there are pics and info my build.
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #3 of 3 Old 10-02-2014, 09:07 AM Thread Starter
OldNewJeeper
In the Build line post 1046. Do you see what looks like a plate just in front of the rocker tube under the door? That plate is what I seem to be missing. There is direct access to the environment there. Lots of lovely crap can be driven down that by the front tires. Yours seems to be steel. Is it? I still cant find photos of what you used the pool noodle for. Do you just stuff a piece of pool noodle in there an paint it black? That might work. Sorry for being so obtuse, home sick and not thinking to clearly.
liner
