Removing side molding - Page 2 - JeepForum.com
post #16 of 19 Old 05-20-2011, 06:53 PM
sbxj
sbxj's Avatar
You did a great job on the painting but unfortunately even with a lift all the door flinging motorists will soon expose the white paint.
I know because I painted mine (and bumpers) with SEM Jeep Cherokee Gray and almost every week I come out to a new ding in the molding. I can't imagine how ****ed up my Jeep would look if I had removed the molding.
I hope it goes better for you.
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #17 of 19 Old 05-20-2011, 07:31 PM
konatown69
Thats why you get/make some sliders that extend out a bit so when people swing their doors, they hit the sliders and not your door
____________
1999 Cherokee Classic, 4.0, AW4, Np242 {HP30 & 8.8 4.56's & locked - build under construction}
konatown69 is offline
post #18 of 19 Old 07-08-2013, 07:52 PM
xjjames1
Does anyone have a Cherokee that has the rear side plastic bumper corners I removed my rear bumper an put on a steal one. I noticed after removing the plastic that there are metal brackets that the plastic slides onto any ideas on easy removal of the metal brackets? I was thinking about drilling the rivets out and hoping the brackets fall off and welding the holes.
xjjames1 is offline
post #19 of 19 Old 07-09-2013, 06:31 PM
konatown69
You're on the right path, that's the easiest way to get 'em off. You might want to think about cutting and folding the corners like this --- http://www.jeepforum.com/forum/f11/c...t-way-1007865/
but I bet if you do it right drilling out those rivets and welding up the holes will look good.
____________
Removing Cherokee Side Molding/Painting end caps dlynch31 XJ/MJ Cherokee Non-Technical Forum 12 01-26-2011 09:16 PM
Removing molding (trim?) from a '93 Cherokee JMan1992 XJ Cherokee Technical Forum 2 10-14-2009 02:46 PM
Write up: Removing side molding off 97+ XJ's *PICS* JeepXJsport12 XJ Cherokee Technical Forum 13 08-10-2009 09:39 AM
Removing Window Molding? 1990XJNY XJ Cherokee Technical Forum 2 11-28-2006 04:43 PM
Side molding Razor. XJ Cherokee Technical Forum 3 03-23-2006 12:22 PM
