red top pooped out on me - Page 2 - JeepForum.com
post #16 of 39 Old 08-11-2014, 12:18 PM Thread Starter
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
I guess I jacked it up then, because I didn't do either of those things. It didn't get used much, but it was 4 years old and I never disconnected it. I have no complaints about the battery at all.
koolaid5 is offline
post #17 of 39 Old 08-11-2014, 12:21 PM
SSellers
Check the voltage on it. If it's below 11V you may be able to recover it using the parallel charge method. Take a look at Optima's FAQ for how to do it. You just need another good battery, a pair of jumper cables, and a charger that won't put out over 15V and 10A.
Steiner
1998 XJ Classic driver
1998 XJ Sport spare parts supply
SSellers is offline
post #18 of 39 Old 08-11-2014, 12:21 PM
wizardPC
I had a yellow top on my 93 and a red top on my 99 and never had any problems. Unfortunately, I've been reading that in the last few years they've really gone downhill after being bought.
Design previews and mad kid pics on
wizardPC is offline
post #19 of 39 Old 08-11-2014, 12:25 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Originally Posted by SSellers View Post
Check the voltage on it. If it's below 11V you may be able to recover it using the parallel charge method. Take a look at Optima's FAQ for how to do it. You just need another good battery, a pair of jumper cables, and a charge rate of maybe 2A.
Auto Zone tried to charge it and it failed. Taking that and the fact that the one corner got real hot, you still think I might be able to salvage it?
koolaid5 is offline
post #20 of 39 Old 08-11-2014, 12:26 PM
SSellers
Yep, five years ago they dropped their prorated warranty as well.
Steiner
SSellers is offline
post #21 of 39 Old 08-11-2014, 12:27 PM
SSellers
Well.....how much faith do you put in Auto Zone?
Steiner
SSellers is offline
post #22 of 39 Old 08-11-2014, 12:32 PM
SSellers
http://www.optimabatteries.com/en-us...ip-articles/#3
Steiner
SSellers is offline
post #23 of 39 Old 08-11-2014, 12:46 PM
skyway0018746
My jeep just sat for a month . Hopped in and she cranked like i just shut it off.
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #24 of 39 Old 08-11-2014, 01:06 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Thanks for the link. Notice the part about excessive heat indicating an actual problem? Yeah, I'm guessing mine is still ****ed.
koolaid5 is offline
post #25 of 39 Old 08-11-2014, 01:07 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
I'm leaning towards an exide from tractor supply now. Just not sure what size. Looks like it will be right around $100
koolaid5 is offline
post #26 of 39 Old 08-11-2014, 01:17 PM
bobthecatkiller
My junkyard test then resells battery's that come in, usually around $20-$25 per battery.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #27 of 39 Old 08-11-2014, 03:00 PM
skyway0018746
I have an exide agm group 78 .
post #28 of 39 Old 08-11-2014, 03:01 PM
nolanbalzarini
the battery shop near me has re-manufactured optima for 80$
nolanbalzarini is offline
post #29 of 39 Old 08-11-2014, 03:04 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Did you get it at Tractor Supply? That's what I think I am going to pick up on the way home tonight.
Does anyone know what the letter designator stand for in the nomenclature?
78DT, 78DTS, 78X. . . ?
koolaid5 is offline
post #30 of 39 Old 08-11-2014, 03:05 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
How does that help me?
Hahahaha
koolaid5 is offline
