red top pooped out on me - JeepForum.com
post #1 of 39 Old 08-10-2014, 10:02 PM Thread Starter
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
Well, just when I thought I was wrapping up things on the Jeep and possibly getting close to being able to get it inspected. . . This happens. . .
Optima told me to go **** myself and I don't have the cash for a new one. SO, what cheap battery can I toss i n this thing and at least get a year or two out of it? I want to slap in the biggest, cheapest brick I can. I'm not using the standard battery box, so I'm not limited to that size. I'm not running any lights or other accessories, but I do have a winch. Hopefully I won't have to use it too much, but the battery needs to perform when I do need it.
Soooooo. . . Thoughts?
koolaid5 is offline
post #2 of 39 Old 08-10-2014, 11:12 PM
jonsnw93
Look at SAMs club. That's where I got mine
jonsnw93 is offline
post #3 of 39 Old 08-10-2014, 11:15 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Don't have a Sam's club. How much was it?
koolaid5 is offline
post #4 of 39 Old 08-11-2014, 05:43 AM
SSellers
Wal-Mart EverStart Maxx. Never had a problem with any of them. Look for the "JCI" or "Johnson Controls" label on it as I think some may be made by Exide now. Johnson seems to build a better battery.
And there's really no such thing as a cost conscious battery anymore as far as I'm concerned.
Steiner
1998 XJ Classic driver
1998 XJ Sport spare parts supply
SSellers is offline
post #5 of 39 Old 08-11-2014, 05:57 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Which ever start do you have?
koolaid5 is offline
post #6 of 39 Old 08-11-2014, 06:05 AM
SSellers
I have three. The XJ is still running the whatever brand battery that was in it when I bought it. They have a battery application module at the store. Since you're not limited on size I reckon you could go with the one like I put in my Hemi Durango if you wanted more CCA than what one for an XJ would have. Or look at one spec'ed for a 2007 or so GM HD truck.
Steiner
SSellers is offline
post #7 of 39 Old 08-11-2014, 06:35 AM
jonsnw93
jonsnw93 is offline
post #8 of 39 Old 08-11-2014, 06:37 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
That's a good price. Just don't have a membership or one close. Thanks
koolaid5 is offline
post #9 of 39 Old 08-11-2014, 08:36 AM
skyway0018746
When your ready to spend money on a good battery go with an exide agm battery. Thing cranks so fast! Opima sucks .
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #10 of 39 Old 08-11-2014, 08:43 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Which one do you have? It doesn't look like they are crazy expensive.
Looks like I AM restricted in the physical size. I forgot about my ballistic fab battery box. So, unless I want to buy a new one I need to stick to the same size as my red top.
Right now I'm leaning towards a Napa $65 special.
koolaid5 is offline
post #11 of 39 Old 08-11-2014, 11:03 AM
skyway0018746
I have a different one then stock . I believe is close to same size but has side terminals ( chevy style ) also AutoZone batteries aren't bad I have one in my ranger put it in about 5 yrs ago. Listen to the radio all day and starts fine. I can get you a part number on the exide if you want .
post #12 of 39 Old 08-11-2014, 11:07 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Sure, I'd appreciate a part number.
I might just pick up one from Auto Zone. I have to go back there to get my optima anyway. That's who tested it for me yesterday.
koolaid5 is offline
post #13 of 39 Old 08-11-2014, 11:38 AM
skyway0018746
Ill get the number tonight. When my yellow top failed it passed all the tests but wouldn't hold a charge over night .
post #14 of 39 Old 08-11-2014, 11:54 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
I've had to jump mine a bunch, but I figured that was just because it would sit for months at a time without being started. Yesterday I jumped it and tried to again with no luck, so I put it on my charger. It never charged and the one corner got REALLY hot.
koolaid5 is offline
post #15 of 39 Old 08-11-2014, 12:16 PM
SSellers
Did you use an AGM charger on it? Optimas are pretty easy to destroy with a regular charger if it puts out over 10A.
Also if they get down too low you have to put another battery in parallel with an Optima to charge it.
Steiner
SSellers is offline
