rebuild or not to rebuild - JeepForum.com
post #1 of 11 Old 09-25-2013, 10:30 AM Thread Starter
desertratXj
1997 XJ Cherokee
i have a 1997 jeep Cherokee sport with a 258 4.0 motor. the vehicle has 165,000 miles and im wondering if i should have the motor rebuilt or not. can anyone help me out and maybe give me some advice on choosing a shop to take it too.
desertratXj is offline
post #2 of 11 Old 09-25-2013, 10:34 AM
dundee23
does it run good ? and have good compression ? no need to waste money if its not broken.
ZJ if you dont know you cant afford it !!!
dundee23 is offline
post #3 of 11 Old 09-25-2013, 11:05 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wondering why you think the motor needs rebuilding ?
CJ7-Tim is offline
post #4 of 11 Old 09-25-2013, 01:09 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
It's just getting good and broken in.
***Chris***
chris87xj is offline
post #5 of 11 Old 09-25-2013, 02:56 PM Thread Starter
desertratXj
1997 XJ Cherokee
the kid that had it before me didn't take good care of it how2 far will these motors go before they need rebuilding?
post #6 of 11 Old 09-25-2013, 02:57 PM Thread Starter
desertratXj
1997 XJ Cherokee
it runs good has some torque and power too it is there anything i can do to upgrade the engine or performance without taking out the motor itself
post #7 of 11 Old 09-25-2013, 04:08 PM
mschi772
1997 XJ Cherokee
Expect AT LEAST 200k miles from a 4.0 that is even remotely cared for. Many hit 300k, and I know of at least one that has gone over 600k. For many of your questions, familiarize yourself with JeepForum and/or Google. The XJ has been around a long time; most things have already been covered quite well.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #8 of 11 Old 09-26-2013, 08:29 AM
dundee23
How long they last depends on how you maintain everything from now on. Enjoy
dundee23 is offline
post #9 of 11 Old 09-28-2013, 12:57 PM
AGDubyaJ
Originally Posted by desertratXj View Post
how far will these motors go before they need rebuilding?
the 4.0L is simply one of (if not "the") most bulletproof engine ever made, Ive been through 2 XJs, a WJ, and a ZJ- all 4.0s. NEVER had any issues with engine itself, the body, suspension, and/ or transmissions always fall apart long before the 4.0L does.
dont even think of rebuilding the motor unless its knocking or has low compression, low oil pressure due to worn bearing/ seals... even then, it should keep running for a while.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #10 of 11 Old 09-30-2013, 10:18 PM Thread Starter
desertratXj
1997 XJ Cherokee
thanks guys its my daily driver but im making it off road ready at the moment.
post #11 of 11 Old 10-01-2013, 05:53 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Change the oil. Use good oil filters like Wix or Napa Gold. Shine a light into the oil filler hole and assess how much, if any, sludge is built up in there.
Do a full tune-up including NGK plugs, Belden plug wires, Premium cap and rotor with brass contacts. All available at Napa.
Clean the throttle body and make sure the air filter is in good shape.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
