Rear Upper Shock Mounts - JeepForum.com
post #1 of 10 Old 06-04-2012, 07:50 PM Thread Starter
Cherokeekid88
1997 XJ Cherokee
When i first installed my lift on my 97 Xj, I snapped all four of my shock bolts...so I drilled them out and used new hardware to mount them through the rear cargo area. i am getting some Bilsteins for my bday and I want to change this up a bit...any idea how I can strengthen the area without fabbing? (no welder, grinder available) Was thinking about just using some nice grade 8 bolts with some nice washers and nuts.......or I guess I could use some BPE? even though the holes at the top have been drilled out???
97 XJ 4.0 Auto D30/29 Sp. 8.25. Yukon 4.10's
4.5" IRO Long Arm Kit - 33x12.50x15's
HD Offroad Engineering Shackle Relocation Brackets
Bilstein 5100's - Magnaflow Exhaust.
Cherokeekid88 is offline
post #2 of 10 Old 06-04-2012, 08:12 PM
Motorcharge
Put an ad on craigslist and find yourself a local welder to throw in some steel to reinforce it. Shouldn't cost much.
Kinda hard to make suggestions without pictures of what you're dealing with.
As for the bolts, grade 8 is absolute overkill. Hell, grade 5 is generally what's used to hold a body to a frame.
http://www.rockcrawler.com/techreports/fasteners/index.asp
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 10 Old 06-04-2012, 09:45 PM
Spokes
u drilled through your floors?? u coulda used a punch and a hammer and had same results minus the holes lol i would just use some grade 8 bolts and washers. its not like your going baja style haha
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #4 of 10 Old 06-04-2012, 11:22 PM
DerMeister
Yea, punch out the old nuts welded to the frame then fish new bolts/washers in there with some wire.
Takes 30 minutes.
DerMeister is offline
post #5 of 10 Old 06-05-2012, 08:56 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The shock mounts are plenty strong as they are, no welding required. Knock the old weld-nuts out with an air chisel and slip in some hardware store bolts with some fishing line or light wire.
CJ7-Tim is offline
post #6 of 10 Old 06-05-2012, 10:08 AM
ibjeepin95
Find someone who welds and do this, since your going 'steins
ibjeepin95 is offline
post #7 of 10 Old 06-05-2012, 07:35 PM Thread Starter
Cherokeekid88
1997 XJ Cherokee
Might just find someone to clean it up for me and weld some nuts on there so that I can just thread a bolt through the bar pin and bolt it up that way.... shock hoops are awesome, but a bit much.....
post #8 of 10 Old 06-05-2012, 07:50 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I was planning on using these on my rear upper shock mounts. Punch the old weld nuts out and install. Best of all, no floor cutting.
http://www.fastenal.com/web/products...0125658&ucst=t
I got lucky and all 4 of mine came out without an issue. I think it was the massive amounts of Kroil I sprayed in through the triangular holes and using an impact gun.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #9 of 10 Old 06-05-2012, 08:21 PM
Hudson
I had my dad make these at his work. I just welded them right up and bolted my shocks to them. Worked like a charm.
I'm pretty sure you can buy something like this and that's what i would do. I guarantee one of your neighbors has a welder that would be willing to help you.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #10 of 10 Old 06-08-2012, 05:22 PM
jameson250s
any idea the exact dimensions on those?
jameson250s is offline
has anyone NOT broken rear upper shock mounts? JrTjK XJ Cherokee Technical Forum 32 11-21-2015 03:39 AM
Broken rear upper shock mounts + BPE TheVision89 XJ Cherokee Technical Forum 4 01-15-2011 07:19 AM
rear upper shock mounts brewco XJ Cherokee Technical Forum 14 03-08-2008 08:11 PM
Relocating rear upper shock mounts?? Tazjig XJ Cherokee Technical Forum 4 03-28-2007 04:02 PM
rear upper shock mounts 98_classic XJ Cherokee Technical Forum 7 05-09-2006 11:30 PM
