Rear of Jeep, creaking and popping... - JeepForum.com
post #1 of 8 Old 03-05-2013, 12:04 PM Thread Starter
Cherokeekid88
1997 XJ Cherokee
So here lately, Whenever I make a sharp turn or I hit bumps in the road or whatever...I have noticed that there is alot of noise coming from the rear of my jeep...it almost sounds like its coming from the inside....Shocks are RC 2.2 which are not even 1.5 years old. But with the way my shocks are set up. I had to drill the holes out in the stock upper rear shock mounts and I just put washers and bolts through the stock holes and tightened them down...seems to work fine....Leaf springs are full packs that are probably 3+ years old. I can't tell if the noise is coming from the leaf springs or from the shocks, but it is VERY annoying!!! Whenever I get out of the jeep...I can rock the jeep back and forth and hear it...creaking and popping...I have sprayed down the leaf spring bushings with some silcone spray, but it doesn't seem to help....just trying to figure out if its the leaf spring bushings or the shocks themselves either not secured correctly or just bad.....
97 XJ 4.0 Auto D30/29 Sp. 8.25. Yukon 4.10's
4.5" IRO Long Arm Kit - 33x12.50x15's
HD Offroad Engineering Shackle Relocation Brackets
Bilstein 5100's - Magnaflow Exhaust.
Cherokeekid88 is offline
post #2 of 8 Old 03-06-2013, 01:52 PM
VegasGT
1988 MJ Comanche
If they are RC leafs I would put money on bad bushings. They have been pretty bad about premature bushing failure (been there). Even if they arent, popping just from shaking it side to side would have me looking into new bushings anyway. I would also grab the shock bodies and try to wiggle them around, giving them a nice little thrashing to check for obvious play.
Aside from that, turning up the radio louder has been proven to cure a number of irregularities.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #3 of 8 Old 03-07-2013, 06:42 AM Thread Starter
Cherokeekid88
1997 XJ Cherokee
radio is usually my cure for everything...but when the wife is riding with me, she hates the music being loud...so then I have to listen to my jeep creaking and popping when I turn and such plus her complaining....talk about wanting to drive off a cliff
I think they are pro comp 3.5" leaf packs with 1" shackle.
post #4 of 8 Old 03-08-2013, 10:40 AM
Azzy
Who made the bushings? If its Omix Ada, replace them. Mine lasted 600 (hundred) miles.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #5 of 8 Old 03-08-2013, 02:24 PM Thread Starter
Cherokeekid88
1997 XJ Cherokee
I think they are pro comp bushings since i believe that my leaf springs are pro comp.....I would really like to get some new packs, but didn't really wnat to have to put out $300
post #6 of 8 Old 03-08-2013, 03:25 PM
Azzy
They should be good. Its time to start looking over a bit, put it up on jack stands and move things around. If you have movement and play, you should be able to find it.
Azzy is offline
post #7 of 8 Old 03-09-2013, 03:15 PM Thread Starter
Cherokeekid88
1997 XJ Cherokee
How bad would it be to ride around with no rear shocks to eliminate that being it?
post #8 of 8 Old 03-10-2013, 08:57 PM
Azzy
Dangerous, unless you have a perfectly smooth surface to ride on. Ever see those videos of the old jeeps from WW1 trials bouncing around like a pogo? Thats because they just had leafs.
Azzy is offline
