Rear Hatch Release Mechanism Adjustment - How To - JeepForum.com
post #1 of 7 Old 07-07-2012, 05:54 PM Thread Starter
NW99XJ
Mechanisms wear out, it's only a matter of time.
As it so happens, my rear lift gate release mechanism (the thingy that allows you to open the rear gate) stopped working, or was at the very least being very temperamental.
I've been in the doors of many vehicles, and am familiar with how all the rods, and levers, and linkages all work.
So I figured that the mechanism that latches the rear gate closed, and releases to allow you to open it, would have SOME sort of adjustment to it, and if it didn't, I was going to make it.
Here is a write up of how I adjusted it on my 99 XJ, (this should be pretty much the same for all 97-01's, I cannot speak for how it is set up on older Cherokees.)
There are several Phillips head screws that hold on the interior panel on the rear gate/hatch, it is easiest to get to all these, and to remove the panel with the hatch open,
if yours is stuck closed you may still be able to do this, but it may be a bit more cumbersome and time consuming.
Once all the screws are removed, there is only pressure clips holding the panel onto the hatch, use a panel popper, or light force with your hand to remove the panel a little at a time.
Once off you'll have access to the inner workings. The large opening to the right of center is where you'll be working through:
Using a smaller flat head screw driver, or equivalent tool,
Slide the retaining clip off of the linkage that connects the handle/lock mechanism to the release mechanism
(mine was green yours may be a different color.)
You'll want to apply force from the right to the left to remove the clip, it will simply rotate off of the linkage with a little pressure:
Once the clip side of the retainer is off of the linkage, pull/pry the end of the linkage out of the retainer all together (it should come straight out)
Now that the linkage is free, you can make the necessary adjustments. In mine, it is set up so that as you rotate it, the threads engage a forked clip, and will move the rod up and down accordingly.....
I adjusted mine all the way up (so that the majority of the threads would be protruding above the forked clip) - This gave the handle much more leverage on the release mechanism.
Now that your linkage is adjusted, it may be a good time to do some up-keep on the actual release/latching mechanism.
There are three Torx head screws holding the mechanism in place in the hatch.
Remove these three, and the mechanism can be removed from the hatch as a whole.
In mine there was a small wired connector/sensor attached to it. This is easy to remove and there is plenty of slack on the wire to do so.
This mechanism is not a serviceable part, in the sense that you cannot take it apart and replace anything in it.
You can however spray it down liberally with lube, blow it out with an air gun, and grease it.
This is what I did before re-installing it, and putting everything back together.
The assembly process is reverse of the un-install:
  • Re-attach the wired plug/connector to the mechanism.
  • Re-install the mechanism,
    -(its a good idea to tighten the two flat head Torx screws FIRST - the countersinks that these go into will help ensure the mechanism is centered in it's location)
  • Push the linkage securely back into the retainer.
  • Rotate the retaining clip back onto the linkage rod.
  • TEST the operation.
    -(If you need to make any adjustments - the panel is already off, and you will have easy access)
  • Re-install the interior panel - make sure not to over tighten the screws, as the plastic can break.
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #2 of 7 Old 07-07-2012, 07:36 PM
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Yes! This is perfect thanks for the write up, mine has needed this since I bought it.
14JK -
98XJ
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline
post #3 of 7 Old 07-07-2012, 07:47 PM
Motorcharge
Nice write up, but there's a couple in the FAQ already, but I'm sure one more can't hurt. Shoot EricsXJ a PM about adding it.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 7 Old 07-07-2012, 07:51 PM
Texsun
Great write up!
Texsun is offline
post #5 of 7 Old 07-08-2012, 06:19 AM
Chelsea
The clocks ticking, pops.
Chelsea's Avatar
1999 MJ Comanche
Just did this last week on my XJ. The only thing I did differently was that I removed the clip at the top of the threaded rod, shifted the rod upwards, and reattached the clip lower down on the threads.
Nice job on the write-up
Chelsea
2005 WK Limited, 5.7 hemi, QDii, aFe intake, Magnaflow exhaust, Taylor shorties, Diablosport tuned
1999 XJ Sport, trail rig, lots of goodies
Chelsea is offline
post #6 of 7 Old 08-02-2012, 08:33 AM
CRider74
First thing that came up in my search for my rear hatch not opening...and damn if you didn't make it easy to do. Thanks a ton man, saved me huge headaches! This is why I paid for a membership here.
Smokin' & Jeepin' (Finally!!!)
CRider74 is offline
post #7 of 7 Old 08-02-2012, 09:47 AM Thread Starter
NW99XJ
THANKS!!
Yea the rod can be removed from the clip or vise-versa, and the adjustment made that way just as easily. In fact that's pretty much how I ended up doing mine, and while it was out, I tightened up that clip to make it more snug on the rod.
RIGHT ON! Hey man glad to help out. I don't know how many times this forum has saved me tons in time and money. Honestly, my membership has paid for itself time and time again. So many others have helped me out with good advice and a decent write up, I figure it's the least I can do to give back to the community that has helped me out so much over the years.
NW99XJ is offline
Where to find rear hatch striker lock mechanism? ahuf XJ Cherokee Technical Forum 4 06-20-2012 07:15 PM
99 xj rear hatch adjustment. 01xjltd XJ Cherokee Technical Forum 4 04-16-2012 06:08 PM
Rear hatch adjustment Sturmsoldaten XJ Cherokee Technical Forum 2 10-22-2010 11:14 AM
rear hatch adjustment... famous1688 XJ Cherokee Technical Forum 7 10-28-2008 05:42 PM
Rear hatch adjustment Mountainwinds XJ Cherokee Technical Forum 2 01-27-2008 03:35 PM
