Rear hatch rattle? - JeepForum.com
post #1 of 8 Old 08-17-2011, 07:19 PM Thread Starter
jeepin ruby
Rear hatch rattle?
Anyone elses rear hatch rattling at the latch? Mine just started doing it and its driving me bonkers! Every bump i hit it rattles like hell. It's pretty loud too. Anyone have a solution? I've checked all the rubber gaskets and everything seems to be okey. I don't know what to do...
2012 JKU Altitude Edition... under construction!
2005 WK limited... The wifes.
jeepin ruby is offline
post #2 of 8 Old 08-17-2011, 07:24 PM
dwharton
Try tightening the lift shocks and/or the hinges.
dwharton is offline
post #3 of 8 Old 08-17-2011, 07:39 PM Thread Starter
jeepin ruby
Checked the hinges. I wouldn't think the shocks could be the problem, but its an idea. When its shut and you push in on the door the latch rattles. It's loose somehow. Dosent look like there's anyway to adjust it
post #4 of 8 Old 08-17-2011, 07:47 PM
dwharton
Mine rattles only when off road and on hard bumps or jolts. It used to rattle just on the street, but i tightened everything down (shocks mainly) and it settled down some.
Not sure what the issue is on yours, but good luck.
Just turn the radio up!
dwharton is offline
post #5 of 8 Old 08-17-2011, 09:19 PM
ikenchute
mine did the same thing,(started rattling out of the blue) out turned out that the latch torx bolts in the hatch were loose.
RE6200 EXTREME-DUTY™ SHORT ARM 5.5-INCH: Aussie Lockers in both HP D30 and Chry 8.25 with 4:56's ZJ rear disc's ABS delete 3103-27 cv SYE
ikenchute is offline
post #6 of 8 Old 08-18-2011, 07:55 AM
mountainjock
1988 XJ Cherokee
Try wrapping electrical tape around the latch pin. Also check to interior trim piece on the door, sometimes that comes loose. Is your spare still back there? If so double check that.
mountainjock is offline
post #7 of 8 Old 08-18-2011, 08:19 AM
Durt_Diver
My latch/locking mechanism rattles like crazy. I've gotten used to it though. My sub really sets it off
-Jacob-
lockers don't work unless you have Rubicon stickers
Durt_Diver is offline
post #8 of 8 Old 08-18-2011, 11:28 AM
MCObray
I just started to encounter the same noise! It's driving me up the wall so i'm going to try and tighten the said bolts. Another issues I found was inside those storage compartments (where the stock spare tire should be), I found a plug for something that kept hitting the side of the vehicle everytime I turned hard or hit a good size bump.
1994 Dodge Ram 2500. 12V Cummins Turbo Diesel.
MCObray is offline
Back hatch rattle - cannot stand anymore jimwww XJ Cherokee Technical Forum 16 08-24-2009 08:44 PM
Rear hatch rattle! beater_xj XJ Cherokee Technical Forum 3 12-13-2008 09:17 PM
6x9 in rear hatch and fix to the hatch trim falling down futurefd XJ Cherokee Technical Forum 2 02-26-2007 12:09 AM
Rear hatch leak and possible new rear hatch window anyone know the cost on a new one? twisted_ed XJ Cherokee Technical Forum 1 11-11-2005 06:54 PM
Very annoying rattle out of rear hatch!! amart565 XJ Cherokee Technical Forum 8 03-03-2004 09:09 PM
