Rear blocks - JeepForum.com
post #1 of 10 Old 10-12-2013, 11:41 AM Thread Starter
troydg
Rear blocks
I have a 99 cherokee sport with a 3 inch rough country lift kit.. I wanted to lift the rear 1 inch higher because I like the look but I was thinking about a 2 inch block in the rear.. Any thoughts? Would it look good? Looks bad? Pros? Cons? I'm just curious lol I'm open to criticism
troydg is offline
post #2 of 10 Old 10-12-2013, 12:28 PM Thread Starter
troydg
Could my shocks even handle another 2" in the rear?
troydg is offline
post #3 of 10 Old 10-12-2013, 02:02 PM
Teej
I don't have too much experience with blocks, but from what I've seen, they aren't good for leaf springs, and they promote axle wrap. You'd probably be better off with a 1" lift shackle or a 1" AAL, depending on how you want to do it.
Teej is offline
post #4 of 10 Old 10-12-2013, 04:11 PM Thread Starter
troydg
Interesting, thanks. What's axle wrap?
troydg is offline
post #5 of 10 Old 10-12-2013, 05:11 PM
Teej
Basically, axle wrap is when the axle is twisting under power. It can also make your leaves into an s shape.
Teej is offline
post #6 of 10 Old 10-12-2013, 06:26 PM
rugsucka
If I was looking for a couple more inches of lift on those 3" lift packs without rebuilding them or replacing them, I'd do 1" in block and 1" in shackle.
If the pack is fairly new, you're running stock gears, and has a decent overload spring, you can use a bit of block for lift.
The reason I wouldn't put it all into the shackle is because the shackle lift alone will cause stress on the leaf pack and can cause premature wear. You will also end up with a poor shackle angle and stiff ride.
A bit of both is a better compromise.
rugsucka is offline
post #7 of 10 Old 10-12-2013, 07:21 PM Thread Starter
troydg
Could my shox handle another 1-2"
troydg is offline
post #8 of 10 Old 10-12-2013, 08:42 PM
rugsucka
Maybe if you don't wheel it. You should make certain that you bumpstop correctly so you don't either stuff a tire into sheet metal, or bottom out your shocks.
It is marginally better to fully extend your shocks as the limiting factor if you disconnect and wheel, but bottoming out shocks will wear them out sooner.
Barpin eliminators will give you back an inch front and rear if you don't already have them - then you would probably be OK for shock length.
rugsucka is offline
post #9 of 10 Old 10-12-2013, 08:49 PM
VegasGT
1988 MJ Comanche
Ok, I really wouldnt recommend blocks at all, just from actual first hand experience back in my early days. The OE spring pad is smallish and wears out even the smallest blocks, rounding edges and loosening u bolts. That said, rugsucka has some good points, Ive run a solid 1" block in the past with no issues.
I gotta ask though, what are you trying to achieve here? Just level it out? What size tires are you running? Do you NEED more lift for tire fitment or "just because"? And if you have 3" rear lift, looking to add 2" more, you have more issues than shock length. You'll be in SYE/double cardan driveshaft territory.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #10 of 10 Old 10-12-2013, 09:02 PM
Motorcharge
Small blocks aren't as big a deal as people make them out to be and they're really only an issue if you rock crawl or off road race, really anything with a lot of torque or suspension travel. Plenty of mud trucks run much bigger blocks than 2" without issues. Hell, most modern trucks come with them from the factory now. The big problem with blocks is the cheap ones like to get spit out at ****ty moments.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
