Rare junkyard find today... - JeepForum.com
post #1 of 67 Old 04-16-2013, 03:21 PM Thread Starter
cainxj99
Went out to the local salvage yard for a driver side vent window for my brothers jeep...(trail damage at dtor birthday bash.) as he's gettin that pulled I went lookin around and ran across an '87 and it had the d44 under it! Asked about it and they want $250. Worth it or should I stick with the original plan of swapping to the 8.25. I have the d35 under my '99 right now. Either way its a good upgrade worth putting money in but In the long run there is more 8.25 s out there.
cainxj99 is offline
post #2 of 67 Old 04-16-2013, 03:26 PM Thread Starter
cainxj99
Attach]609274[/attach]
cainxj99 is offline
post #3 of 67 Old 04-16-2013, 03:28 PM
VegasGT
1988 MJ Comanche
For 250 Id probably go ahead and pick it up if it has the same gear ratio as your front.
DTOR huh? You from Kentucky too?
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #4 of 67 Old 04-16-2013, 03:28 PM Thread Starter
cainxj99
Can't load the pic on this thread but its on my registry thread? I'm about an hour north from dtor, Columbus, In.
cainxj99 is offline
post #5 of 67 Old 04-16-2013, 04:01 PM
Motorcharge
Meh, you can swap an 8.8 for a comparable price and have a considerably stronger axle, disc brakes, more gear options, and limited slip.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #6 of 67 Old 04-16-2013, 04:14 PM Thread Starter
cainxj99
Yeah the 8.8 would be a sweet but for a bolt in upgrade I was lookin at these two options. A welder is in the feature but I don't have one yet for the light fab work the 8.8 takes.
cainxj99 is offline
post #7 of 67 Old 04-16-2013, 06:58 PM
ibjeepin95
Yeah, 8.8 or Chrysler 8.25 29 spline is cheaper, 8.8 is stronger, 8.25 is just as strong. XJ Dana 44's are treated like gold and I don't understand why. I had one once in a 87' XJ. I feel they are overrated.
ibjeepin95 is offline
post #8 of 67 Old 04-17-2013, 04:56 AM
DNFJ
A built dana44 vs a built 8.25 is really user preference.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #9 of 67 Old 04-17-2013, 06:25 AM
egodfrey
egodfrey's Avatar
44 is stronger,maybe only slightly but it is stronger
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #10 of 67 Old 04-17-2013, 07:19 AM
DNFJ
Exactly, so it comes down to cost mostly.
Previous:
DNFJ is offline
post #11 of 67 Old 04-17-2013, 10:56 AM
egodfrey
egodfrey's Avatar
up to 35s a 29 spline 8.25 and a D44 will both be just fine.
egodfrey is offline
post #12 of 67 Old 04-17-2013, 01:38 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
And the 44 has way more aftermarket support. such as locker options, gear choices, spline upgrades etc. and all at a cheaper cost too. Aside from the initial purchase price. Those are why I picked the 44 over the 29-spline 8.25 I had
1990JEEPXJ is offline
post #13 of 67 Old 04-17-2013, 01:49 PM
dcorn
I'd say $250 is too much for a D44, but what do I know.
Says who? The internet?
I ran an 8.25 locked with stock shafts on 35's for years and never had an issue. If I decided to go bigger than 35s, I'd lose either one for a D60 or 9".
Find whichever is cheaper and has the gear ratio you want and swap it in. Gears, lockers and shaft options are basically the same and the same price. Swapping one for the other is pointless in my book.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #14 of 67 Old 04-17-2013, 02:53 PM
Motorcharge
And this proves anything how?
D44 has bigger tubes, more splines, and a bigger pinion than the 8.25. It's just a beefier axle, but not by much at all.
I can't see paying $250 though for it when you can get a 29 spline 8.25 for half the price all day long. You're not going to want to run anything bigger than a 35 on either anyway so it's pretty pointless to swap one for the other. Only time I'd bother with an XJ D44 is if I got one dirt cheap and even then I'd turn around and sell it because people think it's somehow the holy grail of axles just because it's rare.
|SOLD|
| June 2015 COTM |
post #15 of 67 Old 04-17-2013, 07:18 PM
BigBadWuf
1992 XJ Cherokee
$250 is a steal, well at least in my area. Around here junkyards would want that much for a dana35.
BigBadWuf is offline
