rallybro 2001 XJ Build - Page 8 - JeepForum.com
post #106 of 170 Old 09-15-2013, 08:06 AM
Luke95
You've got 33s correct? If so you like the 4:10s?
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #107 of 170 Old 09-15-2013, 08:17 AM Thread Starter
rallybro
I have 31s right now. The 4.10s were so that I could jump into 33s and not struggle super bad power wise. So those are coming soon. The 4.10 with 31s though are really snappy. It has a lot more bottom end torque that I lost with the bigger tires. But the gearing does feel a tad short for my liking. That's why I'm excited because 33s should put me back at the just-above-stock feeling I was going for.
rallybro is offline
post #108 of 170 Old 09-15-2013, 09:57 AM
Luke95
34s and 3.55s are so much fun!
I'm glad that the 8.8 worked out mint for you!
I <3 rockrash
Luke95 is offline
post #109 of 170 Old 09-15-2013, 10:16 AM Thread Starter
rallybro
Yeah, so am I! Mathematically 4.10 and 33s will have the same ratio as stock 3.55 with 225/70. So, theoretically, it will correct my speedo, odo, and power/milage all back to essentially stock. I just need to get the 30 in so I can have my 4 wheel drive back!
rallybro is offline
post #110 of 170 Old 09-15-2013, 12:48 PM
Camfam07
looks great! keep up the work.
Camfam07 is offline
post #111 of 170 Old 09-15-2013, 02:48 PM
Luke95
That's mint dude! I may go this route but just regear my 8.25 (I already have 300 into 75 for the axle 230 for the locker)
I <3 rockrash
Luke95 is offline
post #112 of 170 Old 09-15-2013, 03:27 PM Thread Starter
rallybro
That's what I was looking into doing, also, but I wanted disc brakes and gears and to get disc parts off of a ZJ and get the gears and install them, I would have been pretty darn close to how much I set up the 8.8 for
rallybro is offline
post #113 of 170 Old 09-25-2013, 10:50 AM Thread Starter
rallybro
Got all of this rounded out a couple of days ago, just haven't had time to get on here. I tried to take a few more pictures than I did with the 8.8.
Ripped the guts out
Got the new axle painted up with this sweet primer.
I did a CAD-delete and "compound" housing in the HP30. (Meaning that I swapped a few bigger, better parts from the lp30)
Here's how that went:
Tore apart the HP30, removed CAD actuator and collar, as well as the carrier.
I got the seal and block off plate kit from Rusty's, destroyed that seal trying to put it in all sketchy, and went to NAPA and got a new seal. CAREFULLY put that one in and reassembled the carrier.
At this point we tore down the LP30 and replaced a shot u-joint on the passenger shaft, then we installed the LP30 hubs and shafts on the HP30.
We then realized that the calipers on the HP were smaller than on the LP, as well as that the knuckles were 2-piece, so we replaced bad ball joints and swapped the knuckles.
Block off plate
New U and Ball joints
Put on new braided brake lines from IRO
Put on new pads and rotors
And after some wrestling with it, she's in.
rallybro is offline
post #114 of 170 Old 09-25-2013, 04:33 PM
VegasGT
1988 MJ Comanche
Nice work man! Jeep is looking good!
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #115 of 170 Old 09-25-2013, 04:41 PM Thread Starter
rallybro
Thanks!
rallybro is offline
post #116 of 170 Old 10-03-2013, 07:23 AM
DNFJ
Damn looks nice rb.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #117 of 170 Old 10-04-2013, 03:25 PM Thread Starter
rallybro
Finally!
ECGS Special.
rallybro is offline
post #118 of 170 Old 10-22-2013, 06:45 PM Thread Starter
rallybro
Thank you brown Santa!
rallybro is offline
post #119 of 170 Old 10-28-2013, 09:17 PM Thread Starter
rallybro
So lately my front end has been clinking and I narrowed it down to the flex joints on my control arms being loose. I talked to Rough Country and they said to tighten down the threaded washer on the opposite side of the c-clip. And also when I do that, I need to lengthen them to correct the caster.
My only concern in that getting the control arms to line up on either end is a real pain in the ***. Anyone know a trick to line them up while fighting the springs?
rallybro is offline
post #120 of 170 Old 10-29-2013, 09:38 AM
IDIdiesel
Use a ratchet strap to pull the axle into the correct position
2015 Ford F350 crew cab, gasser
2001 Cherokee sport "AGENT ORANGE"
1991 Ford 7.3L IDI- FOR SALE
IDIdiesel is offline
