rallybro 2001 XJ Build - Page 6 - JeepForum.com
post #76 of 170 Old 05-18-2013, 01:44 PM Thread Starter
rallybro
Would putting new clutches in my 8.25 posi trac have any value?
rallybro is offline
post #77 of 170 Old 05-18-2013, 01:55 PM
Luke95
It would be a good idea better traction cheap
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #78 of 170 Old 05-18-2013, 02:05 PM Thread Starter
rallybro
Alright, so I'll do that at least. Mine doesn't even act like a posi when you spin the wheels by hand..
rallybro is offline
post #79 of 170 Old 05-18-2013, 02:14 PM
Luke95
Then it's time for new clutches
Luke95 is offline
post #80 of 170 Old 05-18-2013, 02:25 PM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Not all 8.25s are posi.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #81 of 170 Old 05-18-2013, 02:26 PM Thread Starter
rallybro
Yessir. Does anyone have experience rebuilding these posis? A differential guy in town said it took special tools and is more trouble than anything if trying to do it inexperienced. But I don't know if he was being helpful or just trying to gain business
rallybro is offline
post #82 of 170 Old 06-21-2013, 02:56 AM Thread Starter
rallybro
Took me awhile to reply..
I sent my vin into Chrysler and got all of my parts list, and when I read that I had a LSD, I tested it. But it's worn down since then
rallybro is offline
post #83 of 170 Old 06-21-2013, 10:26 AM
blackradon
Great build you have going on here man! Love the white and keep it up!
blackradon is offline
post #84 of 170 Old 06-21-2013, 01:53 PM Thread Starter
rallybro
Thank you!
So I've had this aspiration for a long time that I really want to take the old heep on the rubicon because its only 5ish hours south of me, and I'm going to California soon anyway.
My questions are: 1. Can she do it? And 2. Would anyone want to join? Because I obviously don't want to do it alone.
I wouldn't risk it how it sits right now, but I'm planning on putting a locker in the 30 and rebuilding my 8.25 posi. And my rock sliders should be done any day now..
I would love to meet up with some forum buddies or really anyone more knowledgable about the trail than I am, and make a trip out of it.
rallybro is offline
post #85 of 170 Old 07-03-2013, 10:21 AM Thread Starter
rallybro
No one?
Sorry for the lack of updates. I've been working my *** off the past couple of months and am hopefully going to be making some big moves on the Cherokee here in the next week or so.
rallybro is offline
post #86 of 170 Old 07-30-2013, 07:06 PM Thread Starter
rallybro
Alright, took DNFJ's advice and went for a Han n Tap. IRO got it to me pretty quick and I found a front driveshaft in town for $60. More than I wanted to pay, but it works.
Out with these
I took the old shaft off and put the car in reverse to guarantee a straight cut. But I got a longer shaft that was about 31" so I had to trim the actual yoke as well. About 5/8". It scared me a little because it got dangerously close to the splines. I cut it with a grinder and cutting wheel then smoothed it even on a bench grinder and made it pretty with a wire wheel.
The drilling and tapping was relatively easy. Using a square socket instead of a tap handle makes quick work of the tap.
And wallah.
rallybro is offline
post #87 of 170 Old 07-30-2013, 07:40 PM Thread Starter
rallybro
I've been trying to make headway lately on upgrading my drivetrain. I ideally would like to do f/r 44s and have a lead on a front 44 from a full size cherokee that I would rebuild, gear and lock, but I'd still need to find a rear. OR I could get a hp30 from the u-pull, then rebuild lock and gear that and my chr. 8.25. Ahhhh, decisions.
Or I could, like, extend the front, drop a 6bt and run 60s...
rallybro is offline
post #88 of 170 Old 07-31-2013, 04:52 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
What size tire do you plan on running? Also, nice work on the HnT.
Previous:
DNFJ is offline
post #89 of 170 Old 07-31-2013, 07:57 AM Thread Starter
rallybro
It mostly depends on budget. Since I'm going to be going to school in the fall, I assume that my work hours will be limited. I only plan on running 33's and that's why I'm fine with the 30/8.25 combo but after checking out more and more builds, 35's would be nice too.
rallybro is offline
post #90 of 170 Old 07-31-2013, 09:46 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
30/8.25 is a good combo I'd stick with it while it's still a DD.
Previous:
DNFJ is offline
