Radio power supply handle an amp??? - JeepForum.com
post #1 of 13 Old 12-22-2013, 04:25 PM Thread Starter
00XJMikey
I was thinking about buying an Alpine KTP-445A Power-Pack to better power (4) Pioneer 6-1/2" speakers.
Do y'all think the radio power supply could safely handle the power load?
00XJMikey is offline
post #2 of 13 Old 12-22-2013, 04:50 PM
PaYankee
Your selections are not worth the money or effort to replace the factory setup.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline
post #3 of 13 Old 12-22-2013, 05:33 PM Thread Starter
00XJMikey
I do not understand how that relates in anyway to my question or the purpose of this thread, but thanks for the reply.
post #4 of 13 Old 12-22-2013, 06:14 PM
PaYankee
Note: The factory radio circuit needs to be a minimum of 15A. If it is not, a separate power and ground will need to be installed for the KTP-445A
I don't know how many amps the factory circuit is. I personally wouldn't do it.
PaYankee is offline
post #5 of 13 Old 12-22-2013, 06:56 PM Thread Starter
00XJMikey
Ok. I'll take everything apart again and run new wires for an amp. Thanks.
post #6 of 13 Old 12-22-2013, 07:28 PM
Motorcharge
For what you'll spend on that you can buy a much better aftermarket deck and speakers.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #7 of 13 Old 12-23-2013, 09:52 AM Thread Starter
00XJMikey
I already have an Alpine cde-143bt and the pioneer speakers I linked. Both bought local for a lot less.
post #8 of 13 Old 12-23-2013, 10:07 AM
MikeHoncho88
2015 JK Wrangler
So you are running an Alpine deck and thinking about adding the powerpack? I ran one of those for 2 years and I was happy with it. You shouldn't have to rewire anything. It comes with a plug in harness. It plugs into the back of your deck, and the harness plugs into it.
The advantage of the power pack is ease of install, and the fact that it can be hidden in the dash. It improves the sound, but not by a lot.
MikeHoncho88 is offline
post #9 of 13 Old 12-23-2013, 10:27 AM Thread Starter
00XJMikey
I only rewired my speaker wiring. I tried to remove just the ends by the speakers, but found it easier to run completely new wiring from the factory radio connector.
Thanks. I don't need a ton of power, I just want to hear my speakers clearer at low volumes.
post #10 of 13 Old 12-23-2013, 11:17 PM
uberxj92
1992 XJ Cherokee
Pre97 is 10amps. And the grounds are weak there.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #11 of 13 Old 12-24-2013, 07:08 AM
Motorcharge
My bad, misread and thought you were trying to use it with the factory radio.
|SOLD|
| June 2015 COTM |
post #12 of 13 Old 12-24-2013, 08:45 AM Thread Starter
00XJMikey
No worries. The factory unit went bye bye once I discovered Bluetooth audio streaming. Now I can enjoy the "luxuries" my fiancee's Ford Escape upgraded sound system has.
post #13 of 13 Old 12-24-2013, 10:01 AM
green97xjsport
1997 XJ Cherokee
The purpose of your thread doesn't in any way relate to this section either, maybe he was just being coy about it instead of a more direct approach.
you would probably get more responses in the correct section....http://www.jeepforum.com/forum/f20/ as your query has nothing to do with any borderline technical advice for an XJ other than that's what your putting it in.
,======o00o.
/__||_l__l,\___\,___
l_--\__\__l_---[]llllll[]
_(o))_____(o))--o-))
green97xjsport is offline
