Question with a lift and MPG - Page 2 - JeepForum.com
post #16 of 24 Old 03-16-2012, 10:13 PM
VegasGT
1988 MJ Comanche
Fat Bob's Garage. True 2" spacers with add a leaf. Cheap and would be great for someone wanting just a BB. Ive ran their spacers before with great luck. Bought another set just in case I decide to do 6.5" later haha.
Anyway, 235s and a BB lift will look great. As for mileage, you shouldnt see any real issues from the lift. Keep the tuneup fresh and use conservative driving habits and you will be fine.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #17 of 24 Old 03-16-2012, 10:17 PM
Durt_Diver
Originally Posted by NJXJ91 View Post
Most 2" spacers are NOT 2".
The Cheaper and Better options?
http://www.ironrockoffroad.com/Merch...egory_Code=PFX
http://www.ironrockoffroad.com/Merch...egory_Code=XLK
or
http://www.4wheelcustoms.com/Products.asp?Cat=1209
The RE kit gives your extra brake lines and new shocks, both not needed at 2".
If your going to spend almost 300 dollars why not fork up a little extra and get OME full packs with coil spacers?
although shocks aren't really needed, they are a really good idea with jeeps this old. btw it would also be a good idea to get new ubolts with that add a leaf.
if you wanna go without shocks, check out fat bobs garage. just make sure you get the long add a leaf. add a leaf's will be a bit more difficult to install than a shackle, but probably more reliable. its up to you.
-Jacob-
lockers don't work unless you have Rubicon stickers
Durt_Diver is offline
post #18 of 24 Old 03-16-2012, 10:44 PM
NJXJ91
So as previously stated... there are better options.
And im sure he isnt rolling around with the shocks that came off the lot..
NJXJ91 is offline
post #19 of 24 Old 03-16-2012, 10:59 PM
Durt_Diver
mine was at 180k
-Jacob-
post #20 of 24 Old 03-16-2012, 11:57 PM Thread Starter
witchdoctor7710
the shocks i think ar off the lot, the jeep was originally owned by some older guy for about 3 years, then up until i got it this jan. it was moved around from dealer to dealer as a rental
"I have been to the dark side.....their cookies are horrible"
witchdoctor7710 is offline
post #21 of 24 Old 03-17-2012, 12:22 AM Thread Starter
witchdoctor7710
Durt, what did you mean exactly by the long add a leaf kit? because this is what I found from Fat bob's
http://fatbobsgarage.com/i-6765326-j...1984-2001.html
Would this be the true 2" kit from Fb's that was stated? I filterd to 01 cherokee, etc, and this is the only 2" BB that i found that included both....oh and what's you opinion on these?
http://fatbobsgarage.com/i-6808184-j...1984-2001.html
Maily becuase i like the look of wheels being a lil wider, but idk if its legal or not..and ive heard wheel spacers can sometimes put strain on the axle n have it snap, etc.
post #22 of 24 Old 03-17-2012, 08:38 AM
VegasGT
1988 MJ Comanche
That is the kit Id go with for the money. The add-a-leaf is kinda short in my opinion, but at 2" I dont think you will see any real issues with it, and I would still feel better about that than a shackle on original equipment leaf springs. Shocks will be fine, but you can upgrade for improved ride quality.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #23 of 24 Old 03-17-2012, 03:17 PM
NJXJ91
With that kit i would select the long leaf option. They wont sag as quick and wont have as harsh of a ride the short AAL would. Just my opinion.
NJXJ91 is offline
post #24 of 24 Old 03-17-2012, 03:56 PM
VegasGT
1988 MJ Comanche
Ah, I was unaware of the long leaf option with Fat Bob's. The longer the add-a-leaf the better, otherwise it will put excessive stress on the leaf pack at each end of the add-a-leaf, doing a similar negative bow shape as the shackles do to some people's leafs. I honestly dont see you having any issues out of the shorter AAL on just 2". You dont strike me as the hardcore wheeler type that flexes out more than Arnold Schwartzenegger in the 80's, so I wouldnt think you would see any issues.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
lift , mpg , tires
Another Lift Question goolsbayjeep XJ Cherokee Technical Forum 10 06-15-2011 04:46 PM
lift question Snoopi8321 XJ Cherokee Technical Forum 3 01-12-2011 04:35 PM
lift question and T-case question sweetzo XJ Cherokee Technical Forum 8 01-23-2006 06:27 PM
lift question jeepcomanche88 MJ Comanche Technical Forum 9 10-01-2005 06:35 PM
Another lift question, what to expect with 3" OME lift HIKNMIK XJ Cherokee Technical Forum 2 10-18-2003 01:07 AM
