question for guys running long arms - JeepForum.com
post #1 of 5 Old 03-23-2012, 06:08 PM Thread Starter
DualPurposeXJ
1994 XJ Cherokee
i was just wondering what you guys did with the stock lower control arm brackets on the frame end. do you cut them all the way off or just grind it until its close to flush with the frame?
If you're in control you're not going fast enough - parnelli jones
DualPurposeXJ is offline
post #2 of 5 Old 03-23-2012, 10:59 PM
lilnapsak
1997 XJ Cherokee
i cut mine off pretty close to the frame, was going to grind them down flush but i got lazy. ill eventually clean them up when i get frame stiffiners
lilnapsak is offline
post #3 of 5 Old 03-23-2012, 11:23 PM
PhilipJ
PhilipJ's Avatar
It's kind of difficult to take them down flush unless you really work at it and cut off a little at a time. If you try to do it all at once (right between the rail and the bracket) your grinder/sawzall will want to press up into the rail and cut it. Out of all the half-*** welded things on XJ's, those brackets are spot-welded in very well. The main concern is the inner edge of the brackets that stick out -- make sure your lower arms will clear them while under articulation.
PhilipJ is offline
post #4 of 5 Old 03-24-2012, 09:02 AM
xj_96_FP
i cut them flush to the frame, then put a krylon touch so they didnt rust
xj_96_FP is offline
post #5 of 5 Old 03-25-2012, 08:12 PM
PhilipJ
PhilipJ's Avatar
Mine aren't perfectly flush, but I'm pretty happy with how they came out considering how much of a pain it was to trim them.
Spot-weld city
PhilipJ is offline
Converting adjustable short arms to long arms djlarroc XJ Cherokee Technical Forum 6 11-15-2009 11:15 PM
question about home made long arms 89SAFARIXJ XJ Cherokee Technical Forum 3 02-11-2009 10:50 AM
long arms or short arms? jersey_jim XJ Cherokee Technical Forum 23 10-29-2007 06:40 PM
Long Arms Shock Question joey-nac XJ Cherokee Technical Forum 18 02-19-2007 03:38 PM
Quick Fitment Question For Guys Running Flowmasters 90xj4x4 XJ Cherokee Technical Forum 4 09-26-2004 03:48 PM
