Putco Headlight Harness Problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Putco Headlight Harness Problems
Ruffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-18-2014, 11:54 AM   #1
shooptube
1997 XJ Cherokee
I installed the headlight harness about a week and a half ago. Everything works great except when I go to turn the lights off. When its in Drive and I shut the lights off, they stay on. Once I shift into Park they turn off and the switch turns them on and off perfectly. Any help would be appreciated. Thanks
A ton of metal on your Jeep, different from, a ton of well-engineered metal on your Jeep.
shooptube is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 12:16 PM   #2
wizardPC
Where did you connect the two red + wires to?
http://GunsCarsTech.com
If I've never pissed you off, give it time.
wizardPC is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 05:57 PM   #3
shooptube
1997 XJ Cherokee
I installed marine terminals right before I hooked up the harness so I just popped them right on to the terminals.
Unread 11-18-2014, 06:00 PM   #4
Motorcharge
1991 MJ Comanche
Battery.
These new sig limits suck. Thanks a lot Canada.
Motorcharge is online now   Reply With Quote Quick reply to this message
Unread 11-18-2014, 06:32 PM   #5
shooptube
1997 XJ Cherokee
Originally Posted by Motorcharge
Battery.
Here's a picture I took. The two red wires are for the harness.
Unread 11-18-2014, 08:53 PM   #6
wizardPC
just making sure you didnt go to the same school of eletricianing that whoever go ahold of my jeep did. The fog lights were drawing power from the ignition harness, and the guy used 16ga speaker wire from there to the lights with no fuse. True Story
Unread 11-18-2014, 08:58 PM   #7
shooptube
1997 XJ Cherokee
Dear god... So did you figure that out before or after your XJ burnt to the ground?
No but in all honesty I can safely say that I'm part of a very small group of high school XJ owners that actually do safe wiring on their vehicle. People at my school hook up amps to their cig lighters...
Unread 11-19-2014, 08:16 AM   #8
wizardPC
I wish that was the only bad electrical story from my current jeep. It really is amazing that it didn't burn to the ground.
Unread 11-19-2014, 11:52 AM   #9
shooptube
1997 XJ Cherokee
So what do you think us causing my issue?
Unread 11-19-2014, 01:04 PM   #10
wizardPC
I want to say that there's weird cross with the neutral safety switch. Do the lights behave the same way in neutral as they do in park?
I'd start at the light switch and trace the wires to the headlights, particularly paying attention to any place the wires get close to the NSS wiring.
