Project XJ004 - Tire carrier - JeepForum.com
post #1 of 16 Old 08-14-2009, 03:00 PM Thread Starter
Apostle
Ok, so wanted a tire carrier and couldnt find one that i could afford. Went to local Upick and found one for a bronco II
So needed to make a bracket to hold it, started with cardboard
worked with that, used 3/16 for the arms, and 1/4 for the base plates
My first weld
On the jeep
Modified bronco II bracket
Finished from side
and back
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #2 of 16 Old 08-14-2009, 04:24 PM
Nick
2006 WK
Looks good!
Nick is offline
post #3 of 16 Old 08-14-2009, 04:27 PM
Wazzuppiggy156
1995 XJ Cherokee
How is that secured to the inside?
HEY, want an XJ overhead console?
Wazzuppiggy156 is offline
post #4 of 16 Old 08-14-2009, 08:16 PM
Tarukai
Looking good. I would totally try doing that, but I have a Gen 2, so the lines might be a little different.
I might try making my own when I get new bumpers, though.
Tarukai is offline
post #5 of 16 Old 08-14-2009, 08:22 PM
XJMuscle98
That is a big *** tire on the back man
it looks good though.
I'm wondering if a Bronco tire carrier would be a pretty direct bolt on carrier. (minus drilling holes and all)
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #6 of 16 Old 08-14-2009, 08:27 PM
aircruiser
aircruiser's Avatar
hmm..looks good..think it would hold a 33?
aircruiser is offline
post #7 of 16 Old 08-14-2009, 08:33 PM
pentastar01
Looks good, hell it looks stock. How much did that cost you? And obviously you mounted it through the quarter panel, but I'm wonderin' if you reinforced the mounts? Not to put it down, put it seems that any tire over a 33 hangin' of could possibly bend the sheet metal.
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline
post #8 of 16 Old 08-15-2009, 12:38 AM
Wazzuppiggy156
1995 XJ Cherokee
My thoughts exactly, you used 3/16 plate to make the mounts then bolted it to 20 ga?
More pics of reinforcement please
post #9 of 16 Old 08-15-2009, 02:29 AM Thread Starter
Apostle
The outside plates have identical matching plates on the inside, so the pressure is spread accross the whole plate, not just the bolt holes. mind you, if the door is forcefully swung open, as in someone pushing it real hard, im sure it would bend metal, but im fixing that with a small piece of steel cable from the bumper to the carrier.
The bottom mount holds more weight then the top one, also one of the reasons it is larger. the tire is a 32x11.50x15. the mount itself is a bit short to hold anything larger, but im going to 31x10.5 so will gain a half inch which will make the clearance perfect. the mount can hold a 35, as long as it is not wider then 11.5
the carrier is also getting a mount for a gerry can, so thats an additional 45 pounds when full, and as it stands now, wont be any problems.
The mounts for the bronco II and also the bronco are cast, no way to modify them to fit the jeep. already looked at that.
total cost:
$18 for carrier
$30 for sheet metal - includes the bottom mount bends
$6 for jigsaw blades to cut the arms
$2 for the liscence plate light. had to move plate to driver side (from center)
welder was a friends, so it was free
–Voltaire
Apostle is offline
post #10 of 16 Old 08-15-2009, 02:15 PM Thread Starter
Apostle
welp, got me worried now (tend to over think things some times)
so, decided to make a vertical mount to tie into the upper mount. make it about 6" long going up the C pillar. with braces that weld into that, and into the upper mount. look like a big L
thats the plan, havent taken off the interior molding to look at what i have to work with.
more pics later this week
–Voltaire
Apostle is offline
post #11 of 16 Old 08-15-2009, 02:19 PM
pentastar01
Hey it never hurts to OVERbuild anything.
post #12 of 16 Old 10-18-2009, 08:31 PM
2doorxj
2doorxj's Avatar
just picked up a bronco 2 tire carrier today for 20 bucks, thanks for the idea!
2doorxj is offline
post #13 of 16 Old 10-19-2009, 09:22 AM
PNW_JesseJames
1990 XJ Cherokee
carrier looks awsome.
off topic: what tail lights are those? I have seen them a few times now. I like the look of them and would like to find a set but I dont know where to look.
PNW_JesseJames is offline
post #14 of 16 Old 10-19-2009, 09:29 AM
jkh
Looks like this to me:
http://fitchva.com/jeep/?p=54
Jason
'98 XJ: UpCountry, bastard pack, 2" spacers, JK shocks, 31" BFG AT's
'81 Honda GL500
Colorado Jeep Club Member #399
jkh is offline
post #15 of 16 Old 10-19-2009, 09:39 AM
XJWren
1994 XJ Cherokee
they are XJ waggey lights
94 XJ
91 XJ
RIP will live on in new jeep!
88 XJ dead!
XJWren is offline
OEM tire carrier jeep-noob XJ Cherokee Technical Forum 9 11-16-2010 10:08 AM
Tire Carrier w/ Tire = Better Ride LordBronz XJ Cherokee Technical Forum 2 07-10-2009 09:54 PM
Best Tire Carrier 96XJ9705 XJ Cherokee Technical Forum 14 03-22-2007 11:17 PM
What size tire can be run on a stock tire carrier hmmhoyhoy XJ Cherokee Technical Forum 8 06-24-2006 08:31 PM
Tire Carrier GriGri XJ Cherokee Technical Forum 5 12-09-2005 04:02 PM
