Project Puck build - Page 2 - JeepForum.com
post #16 of 35 Old 05-29-2013, 12:32 PM Thread Starter
Puck81
Originally Posted by moses21 View Post
Don't leave all that weight in there to long or your leafs will be like that forever ha.
I dont plan on it.
Puck81 is offline
post #17 of 35 Old 06-10-2013, 10:53 PM Thread Starter
Puck81
Well, the next item i wanted to install is now on my rig, a SYE, and let me say it was not fun trying to remove my transfer case. It took the better part of a day to do it, mostly due to my buddy and i dicking off. But we got it done and working, how ever since i am a cheap *** i didnt buy my DS at the same time as the SYE, so now i am running my factory front shaft untill i buy my new used DS from a buddy with a ZJ. So last things i need to get my XJ in the dirt are, my new RE shocks, new DS, SS lines installed, and a shop to look at my front suspension because it pops at the floor boards. I think i did not install it correctly(i am far from mechanicly inclined). So, that is my progress for now, i will update as soon as i install the 35's.
Puck81 is offline
post #18 of 35 Old 06-16-2013, 11:35 AM
Camfam07
wow this was the fastest build ive seen!
Camfam07 is offline
post #19 of 35 Old 06-16-2013, 04:42 PM Thread Starter
Puck81
I am not done yet, i still need a few items done.
Puck81 is offline
post #20 of 35 Old 07-06-2013, 03:34 AM Thread Starter
Puck81
So, i have a set of 35" pro comp
M/Ts ready to go on my rig, how ever i am at a loss on what method to use for my front bump stops. I have been told to use hockey pucks JB Welded together (5 per side front coils) but they keep falling apart. Any advice and some pictures of front set ups for 35's on a 4.5" lift would help out alot.
Puck81 is offline
post #21 of 35 Old 07-08-2013, 12:01 PM
T-REXJ
Very fast build so far, I love the color!
T-REXJ is offline
post #22 of 35 Old 07-08-2013, 12:34 PM
VegasGT
1988 MJ Comanche
Best way to mount the pucks is to drill/tap the spring pad and secure the hockey pucks with a bolt. Sucks cause you have to pull everything apart to do that though lol
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #23 of 35 Old 07-25-2013, 09:29 PM Thread Starter
Puck81
35's are now installed, time to go testing for proper bump stop limits.
Puck81 is offline
post #24 of 35 Old 12-14-2013, 04:09 PM Thread Starter
Puck81
New update, i came up on a pair of dana 60's. Looks like tons and 40's here i come!
Puck81 is offline
post #25 of 35 Old 12-15-2013, 09:18 AM
Camfam07
wow nice! keep us updated i like this rig but it was built so fast that i dont even know what happened! lol lets see some 60's
Camfam07 is offline
post #26 of 35 Old 12-15-2013, 07:30 PM Thread Starter
Puck81
I main reason i am doing to 60 swap so soon, is i bent the front axle housing. I was going to do the swap any ways, this just sped up my plans.
As of now my plans are
5:83's
E-lockers f/r
Long arm swap
Rear shackle boxes
37-40's
Steel wheels 17x8
I will be staying on my 4.5" lift because i dont want a top heavy rig on big tires.
Some guys have told me to step down to a 2.5-3" lift, however, i have found that 4.5 is perfect for the type of wheeling i do in the southwest.
Puck81 is offline
post #27 of 35 Old 12-21-2013, 09:18 PM Thread Starter
Puck81
Welp, i broke my driver side front inner and outer axle shafts right at the u-joint.
Puck81 is offline
post #28 of 35 Old 12-22-2013, 01:53 PM
Camfam07
you must be doing some hard wheeling! especially to need that type of set up.
Camfam07 is offline
post #29 of 35 Old 12-22-2013, 01:58 PM Thread Starter
Puck81
I broke my factory dana 30 shafts just to clarify.
And here in vegas, most trails are rated about 2.5-3.5 on a scale of 1-5.
Puck81 is offline
post #30 of 35 Old 12-22-2013, 02:37 PM
Camfam07
nice! still crazy! takes some force to break those things, guess you need those 60's!
Camfam07 is offline
