Project Puck build - JeepForum.com
post #1 of 35 Old 02-26-2013, 11:08 AM Thread Starter
Puck81
Project Puck build
Now that i have had my XJ for a few months now, it's time for my build thread.
Here it is the day i got it.
Sent from my Imagination
ForumRunner_20130226_100704.jpg   ForumRunner_20130226_100719.jpg   ForumRunner_20130226_100733.jpg   ForumRunner_20130226_100758.jpg
Puck81 is offline
post #2 of 35 Old 02-26-2013, 11:12 AM Thread Starter
Puck81
The specs on it
2001 sport
4.0
AW4
231
LP30
8.25
2" bb puck-AAL lift.
I have used it alot on the trails the way i got it.
ForumRunner_20130226_101045.jpg   ForumRunner_20130226_101100.jpg   ForumRunner_20130226_101113.jpg   ForumRunner_20130226_101203.jpg   ForumRunner_20130226_101233.jpg
Puck81 is offline
post #3 of 35 Old 02-26-2013, 11:19 AM Thread Starter
Puck81
Now time for some upgrades!!
First things first was to get rid of the little 30" tires and up it to 32's. So a buddy and i trimed the fenders to make room, and added some rock sliders.
So now that the easy part is done, next is some lockers and a taller lift.
ForumRunner_20130226_101631.jpg   ForumRunner_20130226_101823.jpg   ForumRunner_20130226_101835.jpg   ForumRunner_20130226_101857.jpg   ForumRunner_20130226_101916.jpg
Puck81 is offline
post #4 of 35 Old 02-26-2013, 02:59 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Man, I love the Moabs. I regret selling mine
April 2014 & 2015 COTM
MOBBiN is offline
post #5 of 35 Old 02-26-2013, 03:44 PM
Weeder1
Nice start! What locker are you looking at?
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #6 of 35 Old 02-26-2013, 05:00 PM Thread Starter
Puck81
Spartans front and rear. This is not a dd. And i do not get snow here in Vegas often.
Puck81 is offline
post #7 of 35 Old 02-26-2013, 05:32 PM
Weeder1
Good choice.
-98 xj sport-
Weeder1 is offline
post #8 of 35 Old 02-27-2013, 09:45 AM Thread Starter
Puck81
Spartans ordered and will be installed March 8th. woot.
Puck81 is offline
post #9 of 35 Old 03-07-2013, 07:49 PM Thread Starter
Puck81
Tomorrow i get my lockers installed. I hope the shop lets me take pictures of the process.
Puck81 is offline
post #10 of 35 Old 03-08-2013, 06:52 PM Thread Starter
Puck81
So i got the lockers in and took my XJ for a quick test, and it performed well. The Spartans are quiet and don't load up and pop. Very smooth on the high ways and only a minor pull when reengageing when letting off the gas.
Puck81 is offline
post #11 of 35 Old 05-14-2013, 05:10 PM Thread Starter
Puck81
Well i got my lift, i am going to try and install it this weekend. I got the RE 4.5" super flex short arm kit with new rear springs.
For prep to make sure things go as smooth as it can, i am PB Blasting the piss outta the bolts on the suspension. My rig lived the first 5 years of its life in Ohio, so some of the nuts and bolts are rust badly. So far this week i am 2 cans into the hose down of each nut and bolt. Some of my buddies say i am wasting money on PB Blaster by using so much, but after seeing what a shop had to do to remove a hub from the front axle due to rust, eff that nonsence, i am going nuts on the prick.
Puck81 is offline
post #12 of 35 Old 05-29-2013, 07:58 AM Thread Starter
Puck81
Ok so i got the lift installed, and it sucked. It took a friend and i a week to install due to rust. I dont know how you rust belt guys do it! Any how, now that the lift is installed the t-case drop kit still needed to be installed, but i found that the bolts and studs wont move with out help. Since i now have a broken t-case cross member bolt broken i the frame with a broken ez out in that, i am going to buy a SYE and just get that installed and forget about how crappy the install went.
Puck81 is offline
post #13 of 35 Old 05-29-2013, 08:04 AM Thread Starter
Puck81
What it looks like at the moment.
To get my XJ home with no drop kit, i had to put almost 400 lbs in the cargo area to compress the rear springs to stop vibes.
Puck81 is offline
post #14 of 35 Old 05-29-2013, 08:05 AM Thread Starter
Puck81
A meme my buddy made for my XJ.
Puck81 is offline
post #15 of 35 Old 05-29-2013, 11:09 AM
moses21
Don't leave all that weight in there to long or your leafs will be like that forever ha.
moses21 is offline
