Project Overland DD - Page 6 - JeepForum.com
post #76 of 349 Old 03-29-2013, 11:16 AM Thread Starter
V1GiLaNtE
Originally Posted by Project1 View Post
thats a sick pick with the storm .. love storms
Thanks man! Winter here has been all over the place and ready for blue skies,warm weather, and camping.
V1GiLaNtE is offline
post #77 of 349 Old 04-02-2013, 05:48 AM Thread Starter
V1GiLaNtE
Or better yet based upon my desires to go bigger for more clearance.. Would I gain anything by throwing on adjustable LCA's instead? Would this help center the axle more and relieve the rubbing on the inner fender? If so I would go with:
Adjustable LCA's
Steering Stabilizer upgrade
IRO Track Bar (Double Sheer)
post #78 of 349 Old 04-03-2013, 10:48 AM
tofuzeppelin
tofuzeppelin's Avatar
I'd say plan A. But I'm no expert. Bad goes to worse you if you load up with extra water and gas your suspension will have some space for movement
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline
post #79 of 349 Old 04-04-2013, 01:56 AM
Kevin108
Sometimes I debate adding a little more lift. At ~3", I can see where LCAs are soon to be necessary.
You should fill out your Jeep info. http://www.jeepforum.com/forum/profile.php?do=extra
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #80 of 349 Old 04-04-2013, 05:46 AM
Kevin108
I've looked at a lot of interior shelves and never thought much about them. Then I saw this.
http://www.expeditionportal.com/foru...724#post506724
Are you keeping your interior space for sleeping or do you hope to get into a rooftop tent?
Kevin108 is offline
post #81 of 349 Old 04-04-2013, 07:41 AM Thread Starter
V1GiLaNtE
I don't want to get bigger but yes it should be the best way to keep tires in check without cutting up the body.
Info filled out
post #82 of 349 Old 04-04-2013, 07:42 AM Thread Starter
V1GiLaNtE
IDEALLY a rooftop tent would be da bomb. But think with that shelf and a full air mattress life could be pretty cushy.
post #83 of 349 Old 04-04-2013, 03:04 PM
VegasGT
1988 MJ Comanche
That may have to be what I do in mine! Past trips Ive went on Ive had to keep cargo light to have sleeping space inside. With a rooftop tent out of my budget Ive considered buying a tent cot to haul around but that idea there may be the best of both worlds. Ive got a few weekend long wheeling road trips I plan to take this year. Maybe I can try and put something together by then.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #84 of 349 Old 04-04-2013, 08:16 PM
Kevin108
My plan A is to add a rooftop basket so when I park I can toss my contents up in it, tarp over them and then sleep inside with nothing extra but the spare tire. My wife and I did a test run last weekend together and were surprisingly comfortable.
Plan B will be something like the shelf above. I haven't taken any measurements yet but it would need to be at least as high as a cooler. I PMed the owner of the above vehicle to try and get some more pictures. I'm not sure how the deck is supported and want to know more about his design. I'll share whatever I glean from him.
Plan C is a rooftop tent although new they cost more than our XJs are worth and I'm not sure I can every justify the expense.
Kevin108 is offline
post #85 of 349 Old 04-05-2013, 06:53 AM
Project1
Now thats is Sweeeet ... I have half of that on my rig but I mounted my spare tire to it ..
Project1 is offline
post #86 of 349 Old 04-06-2013, 06:41 AM
DNFJ
Lots of good ideas in this thread, thank you for sharing.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #87 of 349 Old 04-08-2013, 07:59 PM Thread Starter
V1GiLaNtE
Finally ordered up some JKS discos and sent her to the shop for inspection.
post #88 of 349 Old 04-11-2013, 12:46 PM Thread Starter
V1GiLaNtE
Ok for ****s and giggles I may be picking up another XJ to flip.. Guy wants $1500 but needs
- Exhaust
- Steering Box
- Pad/Rotors
- Rear Driveshaft
2000
4.0 135,xxx
AW4
D35
NP231
3" Lift and "moderate rust and body damage"
I offered him $800.
post #89 of 349 Old 04-11-2013, 01:05 PM
roblaza
You must not be that tall of a guy... LOL I have to lay in there on an angle, and even them my feet hang out the gate
roblaza is offline
post #90 of 349 Old 04-12-2013, 09:58 AM
DNFJ
I'm 5'11" and I have to curl or prop my head up to fit.
Previous:
DNFJ is offline
Willys Jeep Overland Frame Rebuild for XJ? WackPack XJ Cherokee Technical Forum 14 10-05-2011 09:23 PM
Project off road! 1 day project! Empty_Pockets XJ/MJ Cherokee Non-Technical Forum 4 09-10-2010 08:40 AM
Project planning! My dream project to hopefully start this year. Kettles XJ/MJ Cherokee Non-Technical Forum 4 04-15-2010 08:41 PM
Project Redman: 1994 Cherokee Sport Project for a beginner... bowhunter1023 XJ Cherokee Technical Forum 0 01-05-2010 01:06 PM
JGC Overland Drivetrain dan1166 XJ Cherokee Technical Forum 1 08-22-2008 06:30 AM
