Project Motorcharge - Page 16 - JeepForum.com
post #226 of 388 Old 03-12-2013, 08:28 PM
Steelo805
Do you have power windows and locks? If so could you post some pictures of what you did with the wiring to go doorless
Steelo805 is offline
post #227 of 388 Old 03-12-2013, 08:37 PM Thread Starter
Motorcharge
Nope, both are manual. Speakers just have quick connects.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #228 of 388 Old 03-15-2013, 12:33 PM
Steelo805
Any tips for getting the door pins out?
post #229 of 388 Old 03-15-2013, 12:46 PM
KG8893
What year jeep?
Sent from the icon of sin.
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #230 of 388 Old 03-15-2013, 01:16 PM
Steelo805
Originally Posted by KG8893
What year jeep?
96 I have the older style hinges. I plan on cutting them I just can't get the pins out to do so
post #231 of 388 Old 03-15-2013, 02:02 PM Thread Starter
Motorcharge
Drivers side I used a bottle jack on top of a wheel under the door. Once they start movimg they pop right out. Drill the holes out slightly bigger.
Pass side just put weight on the door since theyre pressed in from the bottom. Or use an air hammer.
|SOLD|
| June 2015 COTM |
post #232 of 388 Old 03-15-2013, 03:27 PM
Steelo805
Did you cut your hinges before you took the doors off?
post #233 of 388 Old 03-15-2013, 06:03 PM Thread Starter
Motorcharge
Yes, you have to. Check the FAQ and google, there's a million write ups.
|SOLD|
| June 2015 COTM |
post #234 of 388 Old 03-15-2013, 06:14 PM Thread Starter
Motorcharge
Fixed the 8.25 for now. Don't feel like messing with the 8.8 tomorrow, but I have a bunch of little stuff to get done.
  • Upper shock bolts need to be replaced on the driver's side again. I think the holes are stretched out and they're just pulling through. Gonna cut the floor open in the rear and take a look. Can always tac weld the bolts in place.
  • Replace another busted heater hose and refill w/e coolant leaked out
  • Finish my ZJ seat swap.
  • Headlight adjuster on the drivers side needs to be replaced.
  • Entire thing needs a good cleaning inside and out.
  • Trans pan gasket needs to be replaced.
|SOLD|
| June 2015 COTM |
post #235 of 388 Old 03-16-2013, 01:32 PM
KG8893
Looking good.
KG8893 is offline
post #236 of 388 Old 04-01-2013, 05:08 PM Thread Starter
Motorcharge
The good:
They look badass.
Quietest, smoothest mud tires I've ever ridden on. You'd have no idea they were MTs from just riding on them.
The bad:
Took a ton of wheel weights. A lot of the inside took 8+oz.
Took A LOT of massaging with a BFH inside the wheel wells to not rub on turns. I'd probably have been ok, but it's extremely close at full turn on parts of the wheel well. Definitely going to have to go up an inch before it goes offroad again. They measure 32" but they're a solid 4" larger with the tread than my Uniroyal 32s were.
I've been meaning to do it for a while anyway, but I'm gonna take it into work Saturday and cut the rear quarters flush with the rear door opening and increase the size of the wheel well in the back.
|SOLD|
| June 2015 COTM |
post #237 of 388 Old 04-01-2013, 05:14 PM
mountainjock
1988 XJ Cherokee
Looking good!!
COLORADO JEEP CLUB MEMBER # 312
88 XJ 3" Pro comp lift 31/10.50
231 TC
4.0 I6
mountainjock is offline
post #238 of 388 Old 04-01-2013, 05:23 PM
VegasGT
1988 MJ Comanche
That is all kinds of badassery.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #239 of 388 Old 04-01-2013, 06:33 PM
MattBillyTayloe
The good:
They look badass.
The bad:
This confirms is, I'm getting mtrs looks great man!!
MattBillyTayloe is offline
post #240 of 388 Old 04-04-2013, 08:45 AM
KG8893
They do look nice. I'm jealous.
KG8893 is offline
Project off road! 1 day project! Empty_Pockets XJ/MJ Cherokee Non-Technical Forum 4 09-10-2010 09:40 AM
Project planning! My dream project to hopefully start this year. Kettles XJ/MJ Cherokee Non-Technical Forum 4 04-15-2010 09:41 PM
Project Redman: 1994 Cherokee Sport Project for a beginner... bowhunter1023 XJ Cherokee Technical Forum 0 01-05-2010 02:06 PM
My new project PolarXJ XJ Cherokee Technical Forum 1 12-08-2005 10:18 AM
My new project shadowgamesxj XJ Cherokee Technical Forum 5 11-29-2005 09:12 PM
