Project Motorcharge - Page 15 - JeepForum.com
post #211 of 388 Old 03-05-2013, 04:55 PM Thread Starter
Motorcharge
He was asked. I don't mind answer questions about my build or discussing things I'm doing, but I'll keep reporting the off topic chit chat. Nothing personal and I've specifically asked in reports that no one be reprimanded or anything since I know it's easy to get off on tangents.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #212 of 388 Old 03-05-2013, 05:20 PM
KG8893
Now I know. Feel free to delete this then. I just hadn't seen you ask is all.
Sent from somewhere in Nevada
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #213 of 388 Old 03-05-2013, 05:21 PM
KG8893
Have you decided easy you are doing for the front? Or are you just leaving it as an hpd30?
KG8893 is offline
post #214 of 388 Old 03-05-2013, 05:32 PM Thread Starter
Motorcharge
I'll regear it to match obviously, but that's all I have planned for now. These axles as they'll be after the regear won't ever see a tire larger than a 33. When I go bigger than 33s, which won't be any time soon it'll be 37s and I'll upgrade the rear with a Super 88 kit. No idea about the front yet for that either and having to address steering isn't something I want to mess with anytime soon.
Though I feel like I've said that about half the stuff I've done to this build already.
|SOLD|
| June 2015 COTM |
post #215 of 388 Old 03-05-2013, 05:50 PM
KG8893
My steering is almost scary with my jeep how it sits. If it's was me I would just mess with that. Once I get shows of someone with proper tools I will be. How much lift do you have approximately?
Is a super 88 kit similar to the super 35 kit that eliminates c clips?
KG8893 is offline
post #216 of 388 Old 03-05-2013, 06:02 PM Thread Starter
Motorcharge
2" now. Staying like that on the 33s, maybeeeee 3" but even 2" now seems like it's too much for the 33s for me. This was my real dilema with axles because I don't want to bother with 35s and 37s require too much money for me to invest in anytime soon. I could do Super kits on both the 30 and 8.8 and run them without upgrading the steering, but even that I'm looking at ~$1500 for the kits, plus regearing, plus $4-500 for going up to $300, plus $1200 or so for the tires, and another $4-500 in wheels since damn near nobody makes a 37 in a 15" wheel.
|SOLD|
| June 2015 COTM |
post #217 of 388 Old 03-05-2013, 06:11 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
The Super35 we put in my uncle's TJ did not eliminate the c clips.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #218 of 388 Old 03-05-2013, 06:15 PM
JeepN4KC
JeepN4KC's Avatar
Honestly, I'd maybe go 35s but IMO 33s are perfect.
~Mike~
WK
XJ
post #219 of 388 Old 03-05-2013, 06:28 PM Thread Starter
Motorcharge
I really like 33s for your average build for the average wheeling most people on here will do, but long term this build isn't going to be average.
Small tires and low center of gravity don't mix and they definitely don't mix with what I'm planning on doing long term with the body on this thing.
|SOLD|
| June 2015 COTM |
post #220 of 388 Old 03-05-2013, 06:37 PM
KG8893
There's not much you can do to the body though is there? Or are you going for the pinched nose look?
KG8893 is offline
post #221 of 388 Old 03-05-2013, 07:16 PM Thread Starter
Motorcharge
You'll see.
|SOLD|
| June 2015 COTM |
post #222 of 388 Old 03-05-2013, 10:45 PM
KG8893
I guess I will haha.
I'm assuming when you say 2" of lifting too much for 33s you mean over factory and not saggy old crap? I had about 1/2 inch clearance on their rear wheels with my 33s before lift. 2 1/2 inches wouldn't be too much room to work with either...
KG8893 is offline
post #223 of 388 Old 03-06-2013, 10:46 AM
ibjeepin95
I think you're over thinking it. First, Super kits are a waste of money. You won't break an 8.8 on stock shafts on 35's. a 30 spline upgrade on a 30 isn't worth it. By the time you put that much money into it, you might as well just do a 44 or 60. Beside, if you would break a 30 spline shaft on the trail, good luck finding a shaft. I know most will think my setup is far from ideal, but I have wheeled my setup HARD a lot, and I haven't broke but one 30 shaft. On 35's, HP30, and 8.25 29 spline, stock shafts, locked in both axles. This has been in mostly dry rock, and some in sloppy wet conditions, on rocks, hitting the rev limiter. I'm not knocking you, it's just that a lot of people way over think what they need to run 33's and 35's.
ibjeepin95 is offline
post #224 of 388 Old 03-06-2013, 11:31 AM Thread Starter
Motorcharge
I was talking about the super kit for the 8.8 for 37s, not 35s. I doubt I use the 30 when I go to 37s. Got zero problem running 33s on what I have now and don't plan on ever running 35s.
|SOLD|
| June 2015 COTM |
post #225 of 388 Old 03-06-2013, 01:17 PM
ibjeepin95
Ah, ok see.
Project off road! 1 day project! Empty_Pockets XJ/MJ Cherokee Non-Technical Forum 4 09-10-2010 09:40 AM
Project planning! My dream project to hopefully start this year. Kettles XJ/MJ Cherokee Non-Technical Forum 4 04-15-2010 09:41 PM
Project Redman: 1994 Cherokee Sport Project for a beginner... bowhunter1023 XJ Cherokee Technical Forum 0 01-05-2010 02:06 PM
My new project PolarXJ XJ Cherokee Technical Forum 1 12-08-2005 10:18 AM
My new project shadowgamesxj XJ Cherokee Technical Forum 5 11-29-2005 09:12 PM
