Project high school build! - Page 34 - JeepForum.com
post #496 of 639 Old 09-06-2013, 01:59 PM Thread Starter
ahar9
Only real issue with square is they are weaker compared to appropriately sized DOM if they take hits on the corners, but Clayton uses .250" wall 2" square without issue. Just make sure the flat side is parallel with the ground to less the chance of hitting a corner on a rock.
Yea I gotcha. Well im going leaf springs so im not worried about that until the next rig lol
hold my beer
ahar9 is offline
post #497 of 639 Old 09-06-2013, 04:57 PM
VegasGT
1988 MJ Comanche
Keep us updated, we like pitcharz lol
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #498 of 639 Old 09-06-2013, 05:09 PM Thread Starter
ahar9
Will have some tomorrow for yall
hold my beer
ahar9 is offline
post #499 of 639 Old 09-10-2013, 09:58 PM Thread Starter
ahar9
Front sits alot taller than the rear now. Damn. But I have a pretty wicked gangsta lean. I think my spring hanger on one side is farther forward than the other making it sit taller on one side. Good thing I only tacked them. My axle also looks like its not lined up under the jeep. Like the right wheel is farther back than the left so thats why im gonna move the mount back to even it out and hopefully get rid of the gangsta lean. I have pics but jf went all gay with the size limit
hold my beer
ahar9 is offline
post #500 of 639 Old 09-11-2013, 06:31 AM
VegasGT
1988 MJ Comanche
Get a photobucket and host em. Easy as pie, and way better than teeny tiny JF uploads.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #501 of 639 Old 09-11-2013, 03:10 PM
ibjeepin95
Um, did you measure?
ibjeepin95 is offline
post #502 of 639 Old 09-11-2013, 03:28 PM Thread Starter
ahar9
Yes but apparently not correctly lol
hold my beer
ahar9 is offline
post #503 of 639 Old 09-11-2013, 06:57 PM Thread Starter
ahar9
Ok so I think my problem actually may be that the stock cast in spring perch is taller than the perch I welded on. Hence the gangsta lean. I measured the mounts again and they are only a quarter of an inch in difference so its not that
hold my beer
ahar9 is offline
post #504 of 639 Old 09-15-2013, 01:20 PM
Camfam07
Pics!!!!!!!!!!
Camfam07 is offline
post #505 of 639 Old 09-18-2013, 05:23 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Sure the axle is straight and centered?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #506 of 639 Old 09-20-2013, 06:56 AM Thread Starter
ahar9
Yea all my measurements are within a quarter inch of where they should be. I still havent setup a photobucket but I got the jeep driving. I built a z link draglink just temporary until I could afford crossover steering. I think my z link is bending when I turn the wheel so my steering is loose. Also instead of bump steer I think the z link is bending when the suspension cycles so its like bump steer but very frequent and scary. Definately gonna beef up the draglink.
hold my beer
ahar9 is offline
post #507 of 639 Old 09-22-2013, 08:46 AM Thread Starter
ahar9
Im building a crossover steering arm today. Gonna weld it on and maybe bolt it down to the knuckle too. Make fun all you want but I think it will hold. Im gonna put the knuckle in the oven on 500 degrees for like 45 minutes and then weld it with my mig welder then put it in on 150 degrees to cool down slow. Probably gonna make the arm out of 1/2 inch flat stock. Also yesterday I started putting tj flares on so I could be legal. And heres a flex pic
hold my beer
ahar9 is offline
post #508 of 639 Old 09-22-2013, 10:02 AM
Camfam07
man you got them Front springs on there pretty fast~! lets see some better pics for the leaves not sure if its the pic or not also, but that doesn't seem to be some amazing flex or anything, do you have any diff ones to go off of?
Camfam07 is offline
post #509 of 639 Old 09-22-2013, 10:39 AM Thread Starter
ahar9
The front flexes really well actually. The rear sucks cock though. Ill take more pics
hold my beer
ahar9 is offline
post #510 of 639 Old 09-22-2013, 12:05 PM
Camfam07
ok cool, when I 1st got into jeep I thought it would be cool to have the front leaf springs. but then just never happened. glad to see someone doing this. what did you end up doing with those long arms you made?
Camfam07 is offline
