Project high school build! - Page 30 - JeepForum.com
post #436 of 639 Old 07-27-2013, 10:48 AM
DNFJ
Originally Posted by SFRautomotive View Post
Doesn't matter
Wasn't sure of this, cheers.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #437 of 639 Old 07-27-2013, 10:49 AM Thread Starter
ahar9
Doesn't matter
So you think a solid joint will help?
hold my beer
ahar9 is offline
post #438 of 639 Old 07-27-2013, 10:54 AM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
with the axle wrapping? Yes
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #439 of 639 Old 07-27-2013, 11:14 AM
ibjeepin95
There is more room on the passenger side to run an upper link.
ibjeepin95 is offline
post #440 of 639 Old 07-27-2013, 04:59 PM Thread Starter
ahar9
More, but not alot
hold my beer
ahar9 is offline
post #441 of 639 Old 07-27-2013, 05:00 PM Thread Starter
ahar9
I'm gonna take you guys advice and ill get heim joints and build a new upper mount then see how it works and if it doesn't still then I will a true 3 link
hold my beer
ahar9 is offline
post #442 of 639 Old 07-29-2013, 07:38 PM Thread Starter
ahar9
Super confused. There is 0 play in the upper control arm. I had a friend drive it around today while I watched and it has all kinds of axle wrap but there's no play. Maybe I'm not thinking about it right but it seems like the axle won't rotate on the lca mounts. It has the same effect as if I just welded the control arm to the axle. Could that be my problem?
hold my beer
ahar9 is offline
post #443 of 639 Old 07-29-2013, 07:44 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Soft bushing.
2013 COTY
post #444 of 639 Old 07-29-2013, 08:33 PM Thread Starter
ahar9
Soft bushing.
Explain
hold my beer
ahar9 is offline
post #445 of 639 Old 07-30-2013, 09:54 AM
ibjeepin95
Explain
The upper rubber/poly bushings
post #446 of 639 Old 07-30-2013, 10:02 AM Thread Starter
ahar9
So you guys think that replacing the upper bushings with Heims would definitely fix my problem? Because I don't wana do it for nothing. Also just for my learning sake could you explain why it would help.
hold my beer
ahar9 is offline
post #447 of 639 Old 07-30-2013, 10:05 AM
ibjeepin95
More than likely. It definitely wouldn't hurt anything. You should NEVER run a single upper with a rubber bushing anyways.
post #448 of 639 Old 07-30-2013, 10:35 AM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
A rubber bushing allows to much movement. It may feel tight by hand , but under load it will be soft. And with a single upper it just allows too much movement
2013 COTY
post #449 of 639 Old 07-30-2013, 11:45 AM
ibjeepin95
Exactly.
post #450 of 639 Old 07-30-2013, 01:59 PM Thread Starter
ahar9
Got it. Which of the upper arm bushings is more important to be tight? At the axle or where it connects to the lca?
hold my beer
ahar9 is offline
