Project high school build! - Page 29 - JeepForum.com
post #421 of 638 Old 07-27-2013, 08:12 AM Thread Starter
ahar9
Originally Posted by Luke95
Fix that mount!
I <3 rockrash
Which mount and what do you mean by fix?
hold my beer
ahar9 is offline
post #422 of 638 Old 07-27-2013, 08:22 AM
ibjeepin95
Add another arm. Or, If your dead set on running a 3 link like that, at least put a solid joint in the upper at the axle end...
ibjeepin95 is offline
post #423 of 638 Old 07-27-2013, 08:28 AM Thread Starter
ahar9
Solid joint? As in a jj or heim?
hold my beer
ahar9 is offline
post #424 of 638 Old 07-27-2013, 08:29 AM Thread Starter
ahar9
I know how bad a radius arm setup is on both sides so I'm trying to eliminate the bind by only running 1. And hopefully still be able to drive it on the street
hold my beer
ahar9 is offline
post #425 of 638 Old 07-27-2013, 08:31 AM Thread Starter
ahar9
Oh wait solid joint as in what's on the stock d30? Where the bushing is pushed into the mount?
hold my beer
ahar9 is offline
post #426 of 638 Old 07-27-2013, 08:46 AM
ibjeepin95
Yes
post #427 of 638 Old 07-27-2013, 08:46 AM
ibjeepin95
If I'm not mistaken, a radius arm needs that bind to work...
post #428 of 638 Old 07-27-2013, 08:58 AM Thread Starter
ahar9
Yes
I built the mounts with switching joints in mind. I may just get a heim joint for the axle end an leave the rubber bushing on the other end. But with the weight of a 3/4 ton d44 and having radius arms on both sides, the bind will bend control arms and snap mounts off. Seen it happen on a friends tj. That was a Dana 60 but I'm assuming the weight would be around the same. How would the solid joint be beneficial though?
hold my beer
ahar9 is offline
post #429 of 638 Old 07-27-2013, 10:44 AM
ibjeepin95
Well then ditch that setup. Radius arms suck enough, much less a "3 link" radius arm. You're the second person I've ever seen to run that setup. There is a reason no one runs it. Get on pirate and search 3 link. There is gobs of info on there. It's good to see you started a 3/4 ton build, but I think you rushed into it before you knew what you was doing. The last thing you want is to be driving that b!tch and it blows apart and kills someone.
post #430 of 638 Old 07-27-2013, 10:49 AM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
You need a solid joint on the upper. The rubber bushing allows to much movement.
Heims or jj will work
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #431 of 638 Old 07-27-2013, 11:32 AM Thread Starter
ahar9
My original intent was a tru 3 link until I realiZed how hard it is to find a place for the upper link mount. So I diverted to this. And I read about people with radius arms taking one of the uppers off all the time and saying it works almost as good as a true 3 link so I thought I'd give it a shot. Ill try a solid joint before I ditch it all together. Thanks for your help man
hold my beer
ahar9 is offline
post #432 of 638 Old 07-27-2013, 11:46 AM
DNFJ
Don't most radius arms mount to the drive side axle upper?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #433 of 638 Old 07-27-2013, 11:46 AM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
Doesn't matter
2013 COTY
post #434 of 638 Old 07-27-2013, 11:47 AM Thread Starter
ahar9
Most do but passenger side works to. I think it's better on the driver side though
hold my beer
ahar9 is offline
post #435 of 638 Old 07-27-2013, 11:48 AM
DNFJ
Originally Posted by SFRautomotive View Post
Doesn't matter
Wasn't sure of this, cheers.
Previous:
DNFJ is offline
