Pressing leaf spring bushings into leaf - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Pressing leaf spring bushings into leaf
Ruffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!
Unread 03-26-2015, 10:14 PM   #1
pmurph131
I got the stock XJ blues
pmurph131's Avatar
I I tried a homemade press like this thread suggested but I can't get the bushing to go in straight. http://www.jeepforum.com/forum/f11/h...3/#post9841085
It's a Crown bushing going into a crown leaf and they're both brand new so I'm sure it fits. I used grease.
I tried a vice.
I tried a BFH with both of these methods.
The bushings are now sitting in the freezer overnight because that's the only thing I didn't try.
My air tools are out of commission until I get a new air compressor (probably next week).
What else can I do to get these in?
pmurph131 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:35 PM   #2
FairlanePhil
can you hammer a screwdriver into the seam between the leaf and the loop that holds the bushing to open it up a little? Alsom use lithiu grease.
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is online now   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:41 PM   #3
pmurph131
pmurph131's Avatar
I tried that a little but I could try and wedge it in harder tomorrow. I guess I was on the right track, thanks.
Unread 03-27-2015, 12:03 AM   #4
DunmerBoy
Desert Explorer
DunmerBoy's Avatar
Did you freeze the bushing first?
I did that and the press from that thread after using a dead blow to get them started and worked like a champ
“The mountains are calling and I must go.”
― John Muir
COTM October 2014
- Build Thread -
DunmerBoy is offline   Reply With Quote Quick reply to this message
