Pre-cut door seals? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Pre-cut door seals?
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 12-06-2014, 04:54 PM   #1
Jake_A
Pre-cut door seals?
Anyone have a source for OEM, or good quality door seals?
Ive got water getting inside, and its driving me nuts.
Pulled the windshield, took the pinch weld down to bare metal, primed it, put a new one in.
Replaced all the seals around the door glass.
Checked under dash for anything obvious.
Im running out of ideas, and this is the last thing I can think to replace.
Its a Johnny cash song - Engine is 98, trans is 95, body is 96, doors from a 94
Jake_A is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 08:15 PM   #2
wizardPC
Where is the water ending up? What year xj?
http://GunsCarsTech.com
If I've never pissed you off, give it time.
wizardPC is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 09:11 PM   #3
Jake_A
96, pass and driver front
Unread 12-07-2014, 04:00 AM   #4
bobthecatkiller
You losing coolant? Could be heater core
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 10:15 AM   #5
Jake_A
Negative, and it only ever happens when it rains.
Its not a huge amount, but since I have the carpet pulled, its enough to notice.
Unread 12-07-2014, 09:55 PM   #6
um7267
I have the same issue I think it's funny watching the water swish like a lake on the floor ha
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 11:06 PM   #7
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
1992 XJ Cherokee
Is the drain in your cowl plugged?
Need a server? Buy this one!
COTM - October 2012!
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is online now   Reply With Quote Quick reply to this message
Unread 12-08-2014, 08:38 PM   #8
PaYankee
I stuck some 1/4" nylon rope from lowes around my door seals to push them out instead of buying new ones.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline   Reply With Quote Quick reply to this message
Unread 12-08-2014, 10:17 PM   #9
bobthecatkiller
I had four main places I had to patch up to make my jeep completely water free when it rains.
One was my windsheild, second was my rear lift gate wire boots had cracked and allowed water to come in, third was my rockers which when water splashed up and in the rust holes it would make its way inside, and lastly my driver door seal wasent sealing up because my driver door was and is still saging a little.
