Hey guys,
So I am on the verge of buying an 87 Cherokee to be my new daily driver. The guy has all the maintenance records, 2nd owner, etc. Engine was replaced about 10 years ago and only has 50,000 miles on it, hooked to the stock transmission. Dana 44 in the back, 30 in the front. I test drove it today. Very strong truck. I plan on cleaning up the interior and making it my new daily driver. Definitely going to make the swap to EV6 injectors, replace the belts and probably a few easy tune ups here and there. However, before I buy, here are my concerns:
The wheel is very loose when steering, probably tie rod needs to be replaced? I can manage that easy.
There is a leak of fluid in the transmission to transfer case gasket. How much am I looking at to get a new gasket put in by a mechanic?
The underside is very rust free considering the year, but are there any specific spots to watch?
Is there anything else known to go bad in these cars I should look out for?
Finally, What do you guys suggest I do to it if/when I buy this thing?
Thanks so much!
Thanks so much!
