Popping/clunking noise - Page 2 - JeepForum.com
post #16 of 22 Old 02-07-2012, 07:24 PM
Crispynuggets
Double check your u-joints. If it pops when putting it in gear then have someone shift it while you watch underneath. Obviously not directly under the vehicle.
Crispynuggets is offline
post #17 of 22 Old 02-08-2012, 05:54 PM Thread Starter
Camfam07
There new, cheap ones ill check em and see, but I can feel this when it pops right under my left foot while sitting in the car left of the brake pedal, im leaning at Ball joint gone bad, or this stupid track bar.
Camfam07 is offline
post #18 of 22 Old 02-08-2012, 05:56 PM Thread Starter
Camfam07
Originally Posted by kg4kzv View Post
Might look at your trans mount while your at it. Also just remembered one of our XJs had an issue with the exhaust getting into the front DS. That clunk drove us mad trying to find out what that was and never figured out why. But we are betting the exhaust got tweaked when wheeling across some fallen trees.
Chris
I dont think its the exhaust I will look though at this point im willing to check anything causing it, would a ball joint pop like that when shifting into drive im moving all the weight of the vehicle forward would a ball joint pop like that, when it pops I can feel it under my left foot left of the brake pedal under the vehicle.
Camfam07 is offline
post #19 of 22 Old 02-08-2012, 06:32 PM
Crispynuggets
Are your driveline u-joints new? That's what i was referring to sorry for not specifying.
post #20 of 22 Old 02-08-2012, 07:13 PM
kg4kzv
1995 XJ Cherokee
I don't think ball-joints would would clunk like this in an XJ. They are easy to check just by jacking up your Jeep just high enough so that the tires clear the ground. Grab your tires at the top and bottom (without putting you fingers under the tire) and see if you can move the tire-wheel in a push pull movement. If you have play there your ball joints or unit hub are bad.
It seems to me this is really a control arm issue either axle or body side bushings. They don't need a lot of play in them to make a clunk that is heard and felt from the floorboard.
As Crispynuggets has pointed out bad u-joints on either the front or rear drive shafts could cause a clunk like this that may be transmitted to the floorboard.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #21 of 22 Old 02-12-2012, 10:03 AM Thread Starter
Camfam07
ok, no the u-joints are out of the driveshaft I bought from a salvage yard, I replaced some centering piece inside the front driveline it the u joints looked ok, I dont know how to tell if they are bad or not, they have grease in them and they seemed to be smooth, but I think I will start there and replace the u joint in the shafts, can the TRAC-BAR make this noise?? like the ball joint end of the track bar it connects to the frame and almost sounds like it could be coming from there.
Camfam07 is offline
post #22 of 22 Old 02-12-2012, 10:43 AM
Crispynuggets
Ya it could. You could have someone move the steering wheel back and forth while you inspect the front end. Check tie ends, pitman arm, and the track bar for play. There should be no play. If there is slop in any component replace it.
Rear Clunking/popping Noise from axle? mxboarder17 XJ Cherokee Technical Forum 22 08-29-2009 09:21 PM
clunking noise xj 98/yj 94 XJ Cherokee Technical Forum 6 04-09-2007 07:50 PM
Popping/clunking noise in front end... mws3784 XJ Cherokee Technical Forum 16 03-24-2005 01:09 PM
clunking noise! jeepcrawler XJ Cherokee Technical Forum 9 02-03-2005 12:22 PM
Squeaking/Squeeling noise in turns and Clunking/clicking noise when braking Sackdragger XJ Cherokee Technical Forum 3 05-14-2002 06:04 AM
