Pocket Flares Vs. *New* Flat Flares - JeepForum.com
post #1 of 6 Old 07-10-2010, 11:26 AM Thread Starter
Adrian007
Ive done a bit of searching, and couldnt find anything on this, but I need to get some flares and could use some help.
I just wanted to know which flare will give you the most tire clearance and based on opinions of you guys, which flare will be the better bang for the buck. I read the instructions on the flat flares and it doesnt look like you cut that much out, so thats why Im asking.
Ive also heard that the new flat flares are made of a new stronger material.
Adrian007 is offline
post #2 of 6 Old 07-10-2010, 02:07 PM
keaton
Youre talkin about the bushwackers right?
I think the flat fenders look alot better apparently theyre built better too. But i think thye offer less clearance since you dont haver to cut as much fender out.
My Rigs:
2000 XJ
2003 TJ
keaton is offline
post #3 of 6 Old 07-10-2010, 02:21 PM Thread Starter
Adrian007
Yeah Im tallking about the Wackers. I thought I read somewhere that if you had the pocket flares that you couldnt use the flat flares, but others have said different. I would much rather have the flat flares over the pocket ones because they are cheaper and look badass, but not if they dont give you that much clearance
post #4 of 6 Old 07-10-2010, 02:28 PM
_Trucker
'Bigger Member'
_Trucker's Avatar
1989 XJ Cherokee
you trim less for flat flares, so if you are already trimmed for clearance they wont work.where as the pocket flares will.
Thom
NAXJA member # 3388
_Trucker is offline
post #5 of 6 Old 07-10-2010, 02:38 PM Thread Starter
Adrian007
Im not trimmed at all. I know that you trim less, but bushwacker says you can fit 33's with a 3 inch lift. I just ordered a 6.5" LA kit so by going from what they say, I should be able to fit 35's with the flat flares right?
post #6 of 6 Old 07-10-2010, 02:39 PM
_Trucker
'Bigger Member'
_Trucker's Avatar
1989 XJ Cherokee
i would think so, just make sure you bump stop accordingly.
Thom
NAXJA member # 3388
_Trucker is offline
1999 , cherokee , flares , lift , sport
where to get pocket fender flares suprman4real XJ Cherokee Technical Forum 1 02-04-2010 04:37 PM
Bushwacker pocket style flares bdodge XJ Cherokee Technical Forum 1 04-07-2009 02:59 PM
Bushwhacker pocket style flares with stick bumper? sic2000xj XJ Cherokee Technical Forum 1 09-08-2008 07:34 PM
pocket style flares iwntflares4 2dr XJ Cherokee Technical Forum 1 07-18-2007 08:25 PM
Anyone installed bushwacker pocket flares? mikeypmcg XJ Cherokee Technical Forum 3 08-09-2005 09:43 AM
