PlastiDip rims? - JeepForum.com
post #1 of 6 Old 05-04-2011, 05:23 PM Thread Starter
Hardt114
PlastiDip rims?
So, I'm fairly certain that I'm going to spray my stock cherokee rims with a few coats of plastidip in the next week or so.
Does anyone have a reason that i shouldnt use that product?
Does anyone have any suggestions for tips/tricks when using it?
How should I deal with the minor amount of rust near the lip on my rims?...I was thinking of hitting it with a wire brush then sanding it smooth along with any other rough spots on the rims...
Hardt114 is offline
post #2 of 6 Old 05-04-2011, 05:32 PM
rugsucka
I don't know whether the product will spread well and evenly - and that could lead to balancing issues, but I'm thinking bad idea.
Spraying would need a pretty hefty tip too as it is fairly thick.
Rust - wire brush, sand smooth, shoot with rustoleum to cover, then do whatever.
I Youtubed it - I wouldn't want
to happen with a simple scuff.
rugsucka is offline
post #3 of 6 Old 05-04-2011, 08:16 PM
i3i11yd
my buddy plastidipped his rims on his yota and they look good. he has hit them with the pressure washer and done some light wheeling and it has held up
i3i11yd is offline
post #4 of 6 Old 05-04-2011, 08:37 PM
blueridgexj98
1989 XJ Cherokee
I did it to my wheels and can not be happier it turned out great, its not real glossy so if thats what you want youll have to use paint. I did a little prep, lightly scuffed them then cleaned, it holds up very well, i tried to scratch it to see if it comes off and it just left a light mark no peeling. Its my kind of paint to, cause if your not great with a can and you spray it to heavy in some spots, it evens out.
blueridgexj98 is offline
post #5 of 6 Old 05-04-2011, 08:51 PM Thread Starter
Hardt114
the company makes it in a rattle can...my friend did his camaro with it and i liked the result. I'm interested in the matte look...
would a little paint really make a difference with the balance?
Hardt114 is offline
post #6 of 6 Old 05-04-2011, 08:51 PM
Apostle
2015 KL Cherokee
^ that.
scuff them up with a scouring pad. smooth surface is going to get you that video results
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
cherokee , paint , rims
Rims drewguere XJ Cherokee Technical Forum 17 01-08-2007 12:07 PM
Will 94 OEM YJ rims fit my 90 XJ? XJ Rob XJ Cherokee Technical Forum 1 01-03-2007 09:11 AM
new rims 1990JEEPXJ XJ Cherokee Technical Forum 16 12-27-2006 12:17 PM
Polished Aluminum Alloy Rims or Chrome Plated Alloy rims twisted_ed XJ Cherokee Technical Forum 11 07-11-2005 12:37 AM
will TJ rims fit on a XJ? TXST8tj XJ Cherokee Technical Forum 5 12-13-2004 11:29 PM
