"Plan B" build thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > "Plan B" build thread
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectSavvy Aluminum Gas Tank SkidFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-21-2014, 02:36 PM   #1
S8NNG8
1995 XJ Cherokee
This Jeep is not quite in my possession yet. But I'll be bringing up to par for my son. He is truly a skateboard freak and Plan B is one of his favorite brands, plus his name is Brandon and he was the second child. So yes, Plan B happens to be his nickname as well.
This little beauty is a '90 4.0/auto 4x4 with 266k on the clock, but it runs great and everything crucial seems to be in good working order. Once I have the title in hand we'll start with a buff and wax, clean the chrome steels, and clean up the inside. The power windows and locks seem to be malfunctioning but that can be remedied. Seeing as how this'll be his first car I'll probably just do a 1" shackle and 30x9.50's for now.
This XJ (if it doesn't get wrecked) will be treated to all the good ideas that I won't do to my 2dr: bumpers, trimming, etc...and probably some diamond plate
D3<!L!>3D
S8NNG8 is offline   Reply With Quote
Unread 08-25-2014, 08:14 PM   #2
DunmerBoy
eXJpedition
DunmerBoy's Avatar
gunna be sweet! may be worth it to go with 235s on a first car, can get more street only tires in that size
1998 Jeep Cherokee Sport - Terra the Magnificent
College Student in Genetics, Jeeper and musician
- Build Thread -
DunmerBoy is online now   Reply With Quote
Unread 08-25-2014, 08:23 PM   #3
S8NNG8
1995 XJ Cherokee
Nah, I'll get him a set of BFG/AT's in a 30x9.50 and probably a set of Ranger shackles. The snow gets deep here in the winter. If you don't have the clearance to ford through it, you just don't travel on 2/3 of the streets. Plus, I don't want him to get used to being able to drive it fast on the corners. The 30's will give just enough tipsy to teach him what it's gonna feel like when we lift it. By the time I pull the trigger on a 4.5" for my 2dr, he'll get my 3" setup.
D3<!L!>3D
Unread 08-25-2014, 08:33 PM   #4
DunmerBoy
eXJpedition
DunmerBoy's Avatar
You're a good dad
- Build Thread -
Unread 08-25-2014, 09:26 PM   #5
S8NNG8
1995 XJ Cherokee
Originally Posted by DunmerBoy View Post
You're a good dad
Well thanks bud. My boy has had a hard life without his mom and I feel I'm as much to blame as she is, so I owe him in a way.
D3<!L!>3D
Unread 08-25-2014, 10:07 PM   #6
JeepaholicNinja
Originally Posted by dunmerboy
you're a good dad
x2
2000 Cherokee Classic
...Wishing I wasn't stock
Edit: Wishing everything worked as it should
JeepaholicNinja is offline   Reply With Quote
Unread 08-25-2014, 10:09 PM   #7
JeepaholicNinja
Also i just pulled my door lock fuse when my doors started locking themselves, so going manial is always a good backup with electrical problems....
Unread 08-25-2014, 10:41 PM   #8
S8NNG8
1995 XJ Cherokee
That's one good thing with the locks in this Jeep. The lock toggles can be moved manually. The ones in my 2dr won't move manually, too tight. So ya, unless the locks and windows are a simple fix, they'll become manual.
D3<!L!>3D
Unread 08-26-2014, 01:36 PM   #9
MPETESS10
first I must commend you for doing this for your son.
for what it's worth, there is almost NO true difference in height between a 235/75/15 and a 30x9.5.
TIRERACK says 29" on the 235's and 29.5 on the 30's. .5" in overall height will equal out . .25" additional vehicle heigh/ground clearance. if he can feel a difference in "tippyness" because of a 1/4" he needs to be a professional driver because that takes some major skill
the 235's are "slightly" cheaper (about $10/tire here) but they are easier to find. in the event of a flat that cant be fixed by a patch/plug I dont want to be waiting around for a week for a special ordered tire.
MPETESS10 is offline   Reply With Quote
Unread 08-26-2014, 02:19 PM   #10
S8NNG8
1995 XJ Cherokee
I see what you're saying, but I'm pretty sure the last set of 235's I measured came in at 27". I've pulled 235's off of my first Jeep, replaced with 30's and saw a significant difference.
Anyway, not to argue, I'll check into that before I purchase, thanks.
Forgot to mention it's already sitting on some half decent 235's. Idk about elsewhere, but in MT just about every stock XJ is on 235's.
D3<!L!>3D
Unread 08-26-2014, 02:30 PM   #11
S8NNG8
1995 XJ Cherokee
I'm getting anxious to clean it up. I may just ask my uncle to front me the $$$ for the cause.
D3<!L!>3D
