Personal Reference - JeepForum.com
post #1 of 7 Old 02-15-2016, 02:19 PM Thread Starter
bluejunior
bluejunior's Avatar
Personal Reference
Just making one thread to record and update various reference items I need regularly so I can stop frantically searching all the time. It'll be ongoing as I have little blocks of time to add and update sections.
Please ignore and sorry it'll be popping to the top occasionally.
If you see something here you have a question on, please PM me rather than posting if you can.
Lifted, Locked, Stiffened
bluejunior is offline
post #2 of 7 Old 02-15-2016, 02:37 PM Thread Starter
bluejunior
bluejunior's Avatar
Lift Items and associated:
Drivelines 101: http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml
Spicer CV shaft application guide (for finding 1310 CV shafts of the right length for you): http://www2.dana.com/pdf/J321-CV.pdf
Reference doc for 2.5" wide leaf spring lengths and spring ratings: http://littlekeylime.com/MrN/mrnimages/leaf_springs.png
A good thread on coils and their spring rates: http://www.jeepforum.com/forum/f11/s...-rates-613756/
My favorite homebrew disconnects: http://www.jeepforum.com/forum/f37/better-home-brew-disconnects-538245/
the junkyard parts thread: http://www.jeepforum.com/forum/f11/b...fit-xj-847303/
Gearing calculator: http://www.crawlpedia.com/rpm_gear_calculator.htm
Primer on mild (3"-4.5") lifts for noobs:
First, the ideal lift will depend on use case. If this is a road vehicle that you just want to look and feel a little more "jeepy", then ride quality is king. If it's going to be towing a small boat or pop-up or something for you, you'll want a little stiffer rear end to account for that. If it's going to be trail ridden, then you can afford some components that don't ride quite as well in favor of putting the additional expense towards some basic armor. Even a basic gas tank and TC skid combo will significantly improve the trail survivability of an XJ. There's also different choices to be made as far as maximizing flex within a given lift height. A lower lift pack plus shackle relocation and longer shackles can increase flex over a simple lift pack for example. Looks also come into it, what size tire do you want to run? Do you mind fender trimming? We can help you better if we know what you want to do.
Second, be prepared for a LOT of maintenance costs. Lifts stress maintenance parts and all sorts of other things and even at 3" the costs pretty much always snowball between highlighted maintenance parts, tires and minor modifications that get overlooked (more below). Now for the details.
There's a few different ways to lift the rear we can discuss:
1) Shackle lift: This uses a longer shackle to push the body up from the leaf spring. On worn leaf packs, this causes increased stresses and can actually result in flattening the back half of the leaf spring as much as lifting the body off of it. That bend out of shape adds extra stress and can cause leaves to crack or break entirely. I only suggest a shackle lift in conjunction with brand new leaf packs (either stock height or lifted).
2) Short AAL: This places a very stiff, short leaf into the pack. The arch and stiffness of that leaf allow it to force the entire leaf pack into more of an arch, lifting the body of the vehicle further off the ground. Since that leaf has to be SO stiff to arch the whole pack with poor leverage, it really hurts ride. Short AAL's also create stress points for the rest of the pack at the ends of the new leafwhich can definitely cause cracking or breakage over the long-term. The additional arch also shortens the eye-to-eye length of the stock main leaf, that can pull your shackles vertical, which limits your flex and hurts ride beyond just the characteristics of the spring itself. . That can be combated with shackle relocation. Short AAL's are not recommended unless budget allows nothing else.
3) Long AAL: Long AAL's work just like a short AAL, except that they are nearly the full length of the stock main leaf. This puts them higher in the pack, allows them to be a little softer due to greater area and leverage and generally make for a better ride and more flexibility than a stiffer short AAL. They do suffer from the same problem of shortening the eye-to-eye length and hurting flex/ride if they pull your shackles too vertical. That can be combated with shackle relocation. They're acceptable in general as a budget option. Bastard packs (using leaves from a junkyard vehicle to add more arch to your factory pack) have similar characteristics to Long AAL's. S10's and XJ's are most commonly used to supplement the factory XJ packs, though any 2.5" wide leaf will work if you cut it to appropriate length. Bastard pack options.
4) Lift packs: Lift packs are a whole new leaf pack specifically designed by the aftermarket to lift an XJ a certain amount. They don't suffer from the additional stress problems of AAL's or shackle lifts, and the ride tends to be better due to an internally complimentary spring rate from each leaf. Assuming you don't get the wrong sort, they also don't suffer from the Eye-to-eye length problem. Putting 'HD' packs designed for heavy tire-carrier bumpers or towing can result in their not being enough weight on your rear end to properly compress the spring, bringing up the eye-to-eye issue in absence of a shackle relocation to let you dial in the angle.
Technically there's also blocks but it's a REALLY bad idea on XJ's due to the relatively thin, narrow, weak leaves. Just, don't do it. Period. At most I could only endorse a 1" or less block used purely for leveling purposes.
So...my suggestion for 3"? If you can afford it, get 3" lift packs OR 1.5" lift packs (crown or dorman HD leaves, they mimic the towing/upcountry package factory leaves) and a bolt-in shackle relocation like IRO or RC's (one of the few RC products I'll ever recommend). The latter allows you to use a longer shackle and likely has the greatest flex easily available at 3". It also allows you to dial in shackle angle and helps with ride. If you can't afford new leaves and have to do an AAL, make sure it's a long leaf or a thought-out bastard pack if possible. At 4.5", you'd similarly want 3" lift leaves and shackle relocation. If you need to cut costs, use a full S10 pack under your XJ main leaf to net a 3" lift pack that'll work with relocation to give you 4.5"ish overall.
For the front suspension it's just a matter of getting good coils and/or spacers in a height you like (there are other concerns for the vehicle discussed below). At 3", look around for a well-reviewed kit or coil. Plenty of options. I personally really want MetalCloak's 3.5" springs, or perhaps the Moog Variable rate coils (which lift 1-1.5" depending on things like aftermarket bumpers) + a 1.5-2" spacer. The variable rate coils have excellent reviews for road manners and, due to their design, can be capable of more droop than a similar length single-rate coil. If you want to get advanced, you can talk spring rates. Stock (non-upcountry) XJ springs are, i think, 160 in-lbs. V8 ZJ are 180. 180 +/- 10 is pretty common in aftermarket springs. Stiffer springs will compress less, which makes them more dependable for heavy winch bumpers and the like and also help control body roll. Softer springs will compress more, making ride height more strongly affected by accessories. Softer springs are also more prone to body roll and lateral flex, ESPECIALLY at speed. However, a longer soft spring that is much compressed has more droop/downtravel available than a stiffer, shorter spring. So softer springs are, in some ways, very much preferred for dedicated trail rigs, which stiffer ones are needed for on-road vehicles to help control the additional flexion and keep the vehicle safe during turns, especially on the highway. That has a lot to do with why some guys claim a sway bar is silly (they have stiff springs) and others claim they felt like they'd die the first time the drove without it (softer springs, more roll). Guide to aftermarket springs options and rates. At 3" though, most of that is pretty much a wash other than your personal perception of ride quality, which will be more affected by shock choice. Just get a 3" coil from a reputable brand and be aware that with a stock bumper you may not have enough weight up front to really compress it and you may wind up with more like a 3.5-4" lift. Read reviews before buying a kit to confirm that sort of thing. LOTS of lifted XJ's out there. Someone has probably tried it.
Now for the miscellaneous considerations at 3"
1) The track bar: XJ's use a bar that mounts to the driver's side of the frame and the front axle to keep the axle centered. When you lift, the angle on that bar increases and its effective width decreases. That pulls the axle left, out of center. You can address it by drilling a new hole on the axle farther to the driver's side, but the metal is soft and prone to wallowing out over time. The "right" way to do it is to purchase an adjustable track bar from a vendor like rubicon express, IRO, RC, etc.... Those bars have a changeable length, like a tie rod. you can dial it in to keep your axle centered, and adjust it later if your lift sags, you go higher, or whatever other reason.
2) Brake lines: 3" of lift is kind of pushing the factory brake lines on-road. If it's going off-pavement, they NEED to be replaced. There's no need to blow a lot of money on aftermarket braided steel lines though. Simply get a set of YJ soft lines for the front, and a YJ or Dakota rear line. They're built to the same quality as a factory replacement for your XJ and the pop right on with no modifications. They're just designed for a vehicle with more distance from line mount to axle so they have enough length to accommodate your lift.
3) Driveline angles. At 3" your 94 may not experience any issues, but if you lift and then experience vibrations/growling sounds, it's likely because lifting the jeep changes the angles experienced by your driveline. The rear is the most sensitive. The cheap solution is to drop your transfer case a little bit. That involves removing the transmission cross member and its factory bolts, then reinstalling it with longer bolts and spacers between the crossmember and the body. Easily done for ~$15 at a hardware store. That does reduce your ground clearance however. The 'right' way to do it is an SYE, which moves the the flex in driveshaft length to the shaft, rather than the yoke, and allows you to use a different sort of driveshaft called a double cardan shaft. Look at your front driveshaft and how it connects to the transfer case, that's what the rear would look like after an SYE. In fact if you don't get a "short" SYE, you can use an XJ front shaft from a donor as part of the SYE install to significantly reduce costs compared to having a custom shaft made. Drivelines 101
4) Sway bar links: Your factory sway bar links will not be long enough to maintain a good sway bar angle at 3", and may cause the bar and your coil springs to interfere. Some lifts come with extended sway bar links. Some, like RC lifts, come with relocation brackets that drop the bar itself down and forward. I don't recommend those, it leaves your sway bar out and exposed. If neither or you want to replace drop brackets, an easy, cheap solution is to use TJ sway bar links. They bolt right up and are about 2.5" longer than stock XJ links. Great for a 3" lift. For longer links on a budget, WJ links can have a U bracket added to the top and be used. They can also serve as the basis for homebrew quick disconnects. There's also plenty of options for home-brew or aftermarket "quick disconnect" links, which I recommend if this is going to spend a lot of time swapping between on- and off- road duty but aren't really helpful if this is primarily a road vehicle. My favorite homebrew disconnects.
5) Control arms: Control arms cause a lot of discussion. You can generally get away with stock length arms at 3", though it can result in rubbing where longer ones wouldn't. The point of different length and adjustable control arms is to keep the axle and the driveline at good angles. As you lift, you angle the front of the axle down, resulting in your knuckles turning pointed at the ground instead of parallel to it and causing binding (thus vibes and wear) in your front driveline. Longer Lower LCA's have much the same effect on front driveline angles that shimming can on rear, and can resolve pinion/knuckle angle problems that might otherwise arise. A full set of adjustable arms allows greater control over the forward/rear positioning of the axle in the wheel well and full control over the pinion angle. Basically, if you pick up fixed LCA's as part of the lift kit, like RC sells, then you should use them. If you're buying them separately, you should ONLY bother with adjustables, with priority given longer lower arms. You may also hear mention of long arms, or control arm brackets. Both of these are really only of interest at 4"+ in height and make the arms flatter at neutral ride height height. This improves ride by making the front axle more responsive to bumps (the steeper angle of factory location control arms on lifted jeeps makes more of a bump transfer straight into the unibody, and less of it to the suspension). They also allow more flex, because factory arms are already at a significant part of their droop potentional at neutral height, and longer arms only fix so much of that since they're still at an extreme angle. . Short version: if the kit comes with fixed arms, use them. If not, don't worry about it unless you have problems up front. IF you do, get adjust lowers, if not lowers and uppers, and either google "XJ driveway alignment" or have an offroad specialist shop set it up for you until you're more comfortable.
6) Maintenance parts: When you lift, ANY worn part in the suspension or steering will be highlighted. Balljoints, TRE's, wheel hubs/bearings, driveshaft U-joints. All of those sorts of things are going to complain quickly after being lifted if they're not fairly new. I should also mention here that replacing the control arm bushings up front (whether you get new control arms or not) will really help reduces noise and ride harshness. Sway bar bushings, too. I STRONGLY recommend checking out Rockauto.com or SummitRacing.com. For high-quality steering parts (accept only Dana/spicer or Moog's Problem Solver line. Oh and Timken for hubs) I have not seen anything short of ebay which can match their prices. ~60% the cost of Moog PS stuff at Oreilly's for example.
A final piece of advice: XJ cooling systems are the most commonly ignored and most temperamental of an XJ's regular maintenance systems. Rockauto or Napa (due to who makes their store-branded parts) are the best place to get replacements. If it's all original, or has been several years, I would consider it good sense to do thermostat, radiator hoses, fan clutch and water pump this coming spring. You should do a system flush while you're in there.
There's plenty of brands to look at, I recommend you search this forum and online for reviews. Zone is the one that's better received and almost identical in price to the Rough Country 3", but Rubicon Express, Rusty's, Metal Cloak, IRO, Rusty's, Pro Comp, OME and Rugged Ridge are all examples of good lift companies. You can also assemble your own from your favorite components/features. That's more complicated and can be more expensive, but makes the rig truly built to spec for you.
Let us know if you have questions on any part of that. I know it was a huge block of text but hopefully it helps you understand what you're getting into and what you're comparing as far as the types/completeness of the lift kits your looking at.
post #3 of 7 Old 02-15-2016, 02:45 PM Thread Starter
bluejunior
bluejunior's Avatar
Misc electrical goodies:
non-putco H4 Harness: http://www.ebay.com/itm/330997592807
Electrical/Sensor Diagnosis:
Computer codes key trick: http://www.cherokeeforum.com/f2/jeep...di-obdii-3341/
Rough idle/Heat soak: http://www.wjjeeps.com/tsb/tsb_wj_1803103.pdf CPS:http://www.jeepforum.com/forum/f11/x...ensor-1167378/
The most likely cause of it cranks and cranks but won't start up is the Crankshaft Position Sensor (CPS) located on the transmission bell housing. Often this part is also referred to as the CranKshaft Position Sensor (CKP) CPS/CKP failure is very common. The CPS/CKP can stop working with no warning or symptoms and the engine will not run or the engine may randomly stall for no apparent reason.
Crank Position Sensors can have intermittent “thermal failure”. This means that the CPS/CKP fails when engine gets hot, but works again (and will test as “good”) when it cools back down.
Begin with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. Jeeps do not tolerate low voltage or poor grounds and the ECM/ECU may behave oddly until you remedy this.
Symptoms –
- Starter cranks and cranks but engine won't start up and run.
- Fuel gauge and voltage gauge may not work or display properly.
- You sometimes will have No Bus on the odometer after 30-60 seconds.
- A failed CPS/CKP may or may not throw a CEL trouble code.
- No spark at the spark plugs.
- Fuel pump should run and prime for 3-5 seconds.
If the CPS/CKP is failed sometimes the OBD-II trouble code reader cannot make a connection to the ECU/computer or cannot read Check Engine Light/MIL codes because the CPS/CKP has failed. Disconnect the code reader, disconnect the CPS/CKP wire connector, and reconnect the code reader. If the code reader establishes contact with the ECU and scans, your CPS/CKP is failed and needs to be replaced.
Diagnostic steps to confirm the CPS is the cause of your no-start
You should be able to verify a bad cps, by unplugging it, and turning the ignition key to on. If the voltage gauge and/or the fuel gauge now displays correctly, replace the CPS.
Unplugging and reconnecting the CPS sensor where it connect to the main harness near the back of the intake manifold usually resets the ECU and if the jeep fires right up after doing this you can bet that the CPS is faulty and needs to be replaced.
Exchange the fuel pump relay and the ASD relay with one of the other similar ones in the PDC to eliminate the relays as the cause of the no-start. Confirm that the fuel pump to runs for 3-5 seconds when you turn the ignition key to ON.
Eliminate the NSS as a cause of no start. Wiggle the shift lever at the same time you try to start. Put the transmission in Neutral and do the same. Do the reverse lights come on when the shifter is in Reverse?
Inspect the wires and wire connectors at the O2 sensors on the exhausts pipe. A short circuit from melted insulation or from broken O2 sensor wires can blow a fuse and the ECU/ECM will loose communication. Don’t get tunnel vision and assume the sensor is bad (unless it tests bad with a meter). Damaged wiring or a dirty connector can inhibit the signal from making it to the computer. Inspect/test/clean/repair wiring or connectors as necessary.
CPS Testing
Crankshaft Position Sensor Connector (CPS/CKP)
TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (See Image). Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
TESTING PROCECURE for 1987 – 1990 4.0 L engines
Test # 1 - Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 – 275 Ohms. . If the CPS is out of that range by much, replace it.
Test # 2 - You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
The 2000 and 2001 will have the CPS in the same location on the bell housing, but the wire connector may be on the passenger side, not as shown in the diagram below. Simply follow the wire from the sensor to the connector.
<CKS>
<Coil rail>
<Engine grounds location and cleanup write-up>
****Still looking for a good pic/writeup on the 97+ NSS bypass, but if you look at the NSS side of the connector, with the little latch part pointing up, you jump the bottom corners.
Early NSS Bypass: http://www.cherokeeforum.com/f2/wire...s-93-xj-32698/
NSS Clean and rebuild: http://www.jeepforum.com/forum/f11/n...arting-971621/
Raise and support the front end on jack stands,Well I didn't need to and I think 99% wont need to if you can fit under you Jeep. Next locate it on the passenger side of the transmission it looks like this
This image has been resized. Click this bar to view the full image.
Next you will need a 12mm,23mm socket and a Flat blade screwdriver,Phipps screwdriver,very fine grit sandpaper or emery cloth,electrical connection cleaner and some dielectric tune up grease.
Disconnect the wiring for the switch.Its located near the Oil dipstick in the engine bay should look like this
next you will need to clip the zip ties that hold the wires together
Pry open the locktabs and remove the switch retaining nut and washer.Be-careful there is a rubber washer behind all this.
Remove the switch adjusting bolt.
Slide the switch off the manual valve shaft.
Next you will need to remove the Phillips screws that hold the switch together. Pull apart the two sides but do this CAREFULLY for the arm inside hold two contacts that are spring loaded and believe me its not to fun scouring the shop floor for these things my where so gunked up i had to pry them out."One of the springs flew across the shop I found it 30 mins later with a magnet"
Also there is a rubber gasket that you will never find a replacement for so try not to mess it up but if you do no worries thats what RTV sealant is for.
(The red arrow is the armature arm and the yellow is the Oring/gasket)
Now that apart you'll need the Electrical cleaner This is what i used now wash everything down (nows a good time to clean the connection plug also) get your fine grit sand paper and get to work on the contacts. After a healthy Dose of grease assemble it back together.
Now to reinstall. Position the switch on the valve shaft and install the adjusting bolt finger-tight. Install the washer and attaching nut and tighten the nut but don't bend the tabbed washer yet.Loosen the adjusting nut.
With the transmission in neutral, rotate the switch to align the neutral standard line with the groove on the valve shaft. Hold the switch in this position and tighten the adjusting bolt .Bend the tabbed washer over the retaining nut. Connect the shift linkage rod. Connect the switch wiring. Check the switch operation. The engine should start in P and N only.
(That the Neutral Standard Line)
Misc Wiring Diagrams:
Stereo:
The 12 Volt references for all jeep vehicles: http://www.the12volt.com/installbay/...eard/Jeep.html
<jpgs I can link straight to, or just go through my reference above?>
post #4 of 7 Old 02-15-2016, 02:46 PM Thread Starter
bluejunior
bluejunior's Avatar
Misc Fuel/Air diagnosis:
<Bench test for injectors>
<Fuel pump testing>
<Throttle body/intake cleaning>
post #5 of 7 Old 02-15-2016, 02:47 PM Thread Starter
bluejunior
bluejunior's Avatar
Other misc fix documentation:
post #6 of 7 Old 02-15-2016, 02:48 PM Thread Starter
bluejunior
bluejunior's Avatar
Favorite build/mod threads to be referenced:
The junkyard parts thread: http://www.jeepforum.com/forum/f11/b...fit-xj-847303/
Taurus fan belt fix:
Originally Posted by RockRodHooligan
So I finally found an end-all to a problem that started by doing the Taurus fan swap, and deleting the fan pulley. It wasn't until after I did the swap that I heard the stock 90amp alternator wasn't up to the job, and I swapped out for the 136amp. The problem with both was the belt routing, just wasn't getting enough belt contact on the alternator and crank pulley. I kept going through belts, and even an alternator because of the rubber from the belt slipping getting in it. So I added an idler pulley to the top mounting bolt and ran that for a couple of years, but it still felt half-assed and cobbled together.
Report this image
I eventually ditched the Taurus fan for the DirtBound Off-Road 3-10" fan shroud and 3 Perma-Cool 10"-2300cmf fans, but was still running the less than awesome belt routing. Until one day at the junkyard I found a ZJ 4.0 and happened to notice that the alternator was mounted a little higher, it had more clearance for the larger 136amp alternator, and I could finally ditch my AC delete pulley.
ZJ alternator/AC bracket, no clearancing needed for the 136 amp alternator, and PLENTY of belt contact on the alternator and crank pulleys.
Report this image
I ended up routing the belt the way the early TJ/late ZJ 4.0L is routed(w/o AC, w/PS) but for some reason the TJ/ZJ belt was about 3/4" too short, I'm guessing it may have to do with the larger alternator. Oddly the belt that worked fit a new 2.4L Cherokee, but if anyone asks I'll tell them it's for a '15 Ram 2500 with the 6.4L Hemi....
Report this image
Granted, I don't have the Taurus fan anymore, but this should work perfectly for it as well. It was all direct bolt on(I grabbed the flush timing cover bolts from the ZJ to replace the ones with the studs that the steel XJ alternator bracket bolts to), no cutting/trimming needed. I know one of the big issues that people have with the Taurus fan is with cutting the fan pulley off, and clearancing the steel alternator bracket, once you start there is a point where you know there is no going back, you are completely committed, this completely eliminates that fear. The best part is it's all off the shelf parts, no worries about compromising the factory parts because you're grinding half of the material off or not easily being able to go back to stock.
post #7 of 7 Old 02-15-2016, 02:51 PM Thread Starter
bluejunior
bluejunior's Avatar
Misc Documentation links:
Parts catalogs and spec sheets available here: http://xjjeeps.com/
