parts or not? - JeepForum.com
post #1 of 16 Old 06-07-2010, 07:38 AM Thread Starter
swamp_runner
1997 XJ Cherokee
parts or not?
i just came across a 97 xj with only 64,000 original miles on it for cheap, it needs windows. will the windshield and\or the rear hatch glass outta a 88 xj fit? my 88 is nothing more then parts at this point. so how much outta my 88 can i use on the 97? most specificaly the glass, i knw the door glass wont work. but just an idea of what will, or wont, swap would be nice. im sorry if this info is already posted, i spent two hours searching to no avail... any help is GREATLY appreciated!
thanks, sven
swamp_runner is offline
post #2 of 16 Old 06-07-2010, 07:58 AM
Apostle
interior, front clip, drivetrain and doors. nothing else will fit (not hatch)
glass in the older is held in by a gasket. rear hatch is glued in on the 97. not sure about sides, but they may
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #3 of 16 Old 06-07-2010, 08:06 AM
lowicz96
1995 XJ Cherokee
Anything will fit but might need some messaging to get it to work. I know 1st hand that the front clip is different from 88 to 95 and thus very different to 97. The trans and tcase wont work between those years because 88 trans output is 21 spline and 97 is 23 spline. The interior mounts differently between the two but its doable.
I dont see why the windows wont work, other than the door window with they changed in 97. The windshield should be the same as well as the back side glass. but i guess you will find out for sure
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #4 of 16 Old 06-07-2010, 08:32 AM
Apostle
The tcase can be swapped, just have to swap the input spline (fairly easy). clip can be changed, but have to change fenders as well to make work. the front glass on pre 97 has clips and metal trim ring, the post 97 has a rubber trim ring (not sure exactly how it is held on).
–Voltaire
Apostle is offline
post #5 of 16 Old 06-07-2010, 03:21 PM Thread Starter
swamp_runner
1997 XJ Cherokee
so the windsheild at least will work? my 97 has the gasket around he windshield, (whats left of the windshield anyways) so if its gonna fit, that would be awsome!! this jeep is proposed to be my new DD, so i dont wanna cobble it together. but of course i wann save as much money as possible!
post #6 of 16 Old 06-15-2010, 09:05 PM Thread Starter
swamp_runner
1997 XJ Cherokee
Ok, for anyone interested, the windshield outta a 88 xj WILL NOT fit in a 97 xj... it ws a uneventful learning experience... lol Bt Im still proud of myself for nt breaking anything even after I found out it wouldnt work! Lol! Now I got to decide if I should just pay to have a new one installed, or look for a used one n do it myself....
post #7 of 16 Old 06-15-2010, 09:46 PM
escapeartist
A windshield installed, is under 200 bucks and they come to you. This is something that for some reason has gotten dirt cheap since my first experience with windshield replacement.
escapeartist is offline
post #8 of 16 Old 06-15-2010, 11:05 PM Thread Starter
swamp_runner
1997 XJ Cherokee
REALY? I was just quoted $350 here in central Michigan! Maybe i should keep checking around more, lol
post #9 of 16 Old 06-16-2010, 12:46 PM
escapeartist
It's possibile it is just more expensive out there. Out here they sand the roads so there is a lot of broken glass when spring rolls around. Maybe its a volume thing
Those who say it cannot be done should be quiet and not interrupt those whom are doing it.
post #10 of 16 Old 06-16-2010, 05:55 PM
jeeplesjeeper
safelite go to them they gave me a quote for $200. they will come out and put it if for u, also they have life time warrentys
-Jake
- Big Blue-'98 XJ 6.5inch w/ 33's -R.I.P
-Current- Eep A Green'98 XJ 4.5inch w/ 33s
jeeplesjeeper is offline
post #11 of 16 Old 06-20-2010, 10:58 PM
samuraisavr
i'd part the 88 out and use the money to get what you need for the 97....just an idea
Just
Empty
Every
Pocket
samuraisavr is offline
post #12 of 16 Old 06-21-2010, 01:20 AM Thread Starter
swamp_runner
1997 XJ Cherokee
That is my plan, Bt I'm parting most of the 88 out to myself! Lol, wen I'm dun fixing my 97, I'm gnna use.the ax15 an clutch assembly in my ZJ. I been thru 4 transmissions in my ZJ, so this should be the LAST trans I put in it! Lol. So when I'm done, ill have a body, a moter, transfer case, and axles. Try to part it out, but I can't expect much, its old, beat up, cut fenders, an it'll be half stripped! Lol
post #13 of 16 Old 06-23-2010, 10:42 PM Thread Starter
swamp_runner
1997 XJ Cherokee
Anyone know if the oil pans are the same? They look the same, but the one on my 97 is pretty badly dented...
post #14 of 16 Old 06-23-2010, 10:47 PM Thread Starter
swamp_runner
1997 XJ Cherokee
Oh, an by the way, I bought a new windshield an had it installed for $269 I was a lil nervous about gtting the windshield sealed fully, so I just paid to have it done
post #15 of 16 Old 06-24-2010, 09:56 AM
Apostle
if both engines are 4.0 then the pan should be the same. and nothing wrong with paying to have something done correctly.
i do my own work, but also pay to have windshields replaced
–Voltaire
Apostle is offline
cherokee , swap , windshield
Can I fit 91 parts in a 97? jeeper85 XJ Cherokee Technical Forum 5 01-30-2010 05:43 AM
Cherokee body parts - parts vehicle brianj752 XJ Cherokee Technical Forum 15 01-23-2006 10:23 AM
Few parts anyone know where to get tozier9 XJ Cherokee Technical Forum 3 03-08-2005 07:32 PM
Illustrated Parts Breakdown or Parts Manual? Borinquenknight XJ Cherokee Technical Forum 8 11-17-2004 10:22 PM
Parts! Parts! And More Parts! It's An Emporium Of Xj Parts! Culpeper XJ Cherokee Technical Forum 15 10-19-2003 09:38 AM
