? part in Raybestos Lower ball joint parts bag - JeepForum.com
post #1 of 1 Old 05-01-2012, 12:59 PM Thread Starter
greenlawnjeeper
Is this blue plug for my vehicle? I called Raybestos and the tech dept said "it goes in the axle and you need a special tool for it." I said maybe it's for another vehicle that takes the same part # and when I told him I had a 1996 Jeep Cherokee, he said I need it?
When I took my stuff apart, I had no such part
FWIW, this parts bad had 2 blue plugs (while the other had 1) and no lube plug fitting, just a lube fitting.
'96 Cherokee Country, Magnaflow cat and Borla exhaust, Hella 550's, Up Country suspension, Michelin MS 2's in 235x15 and Edelbrock IAS shocks. 91K orig. miles - the wife uses it ('cept when I borrow it to go huntin').
greenlawnjeeper is offline
Lower ball joint lubrication greenlawnjeeper XJ/MJ Cherokee Non-Technical Forum 4 05-04-2012 10:42 AM
Lower ball joint install sheerlucidity XJ Cherokee Technical Forum 4 06-08-2011 07:01 AM
lower ball joint problem jeepnphreak XJ Cherokee Technical Forum 2 08-07-2009 08:58 AM
Can't get out lower Ball joint CharlieMopps XJ Cherokee Technical Forum 23 10-22-2008 05:20 PM
Lower Ball joint. nujeepguy XJ Cherokee Technical Forum 7 02-17-2008 07:43 PM
