Out with the WJ, In with the XJ! - JeepForum.com
post #1 of 6 Old 05-24-2013, 12:38 AM Thread Starter
AaronUArk
Hey fellas, So I'll keep the story short. I might be getting rid of the ol' WJ and moving on to a '98 XJ. It's a 2 door, forest green, with an I6, standard trans., command-trac t-case and 130k original miles. I learned a hard lesson with the WJ and I want to make sure I do my research this time.
So... any advice on what I should look out for this time around? Any common problems I should expect? Someone on the WJ forum mentioned hearing about an engine problem in the 98-00 XJ's, just like in the V8 WJ's. Anyone know anything about that? Hell, any advice at all on the WJ vs. XJ would be great!
Thanks in advance everyone! I value any and all advice!
AaronUArk is offline
post #2 of 6 Old 05-24-2013, 12:57 AM
seww
1990 XJ Cherokee
Of course you should get an XJ!
The engine "problem" is on 00-01 due to a different head which might crack. 98-99 is supposed to the favorite years among us XJers...
Other than that, the I6 is solid.
Im at work right now but Im sure some guys will chip in. Though a search here will help you right now.
1997 black XJ, I6 4.0, AW4, NP242 (stock)
1990 blue XJ, I6 4.0, AW4, NP242 (stock)
A SUV is not a Jeep. A Jeep is not a SUV.
seww is offline
post #3 of 6 Old 05-24-2013, 11:41 PM Thread Starter
AaronUArk
Thanks for the reply Seww. I guess everyone else was at work too! Glad to hear that the 98-99's are an all around favorite. I just got some better pictures (haven't actually seen it in person yet) and unfortunately I was dead wrong on the color. It appears to be a shade of blue instead of green, but oh well, it's still pretty nice. Thanks for the info, it's much appreciated!
post #4 of 6 Old 05-25-2013, 06:23 AM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
The 98-99's are the models just after a major design overhaul with reguards to underhood wiring,I believe th 97 may have a different harness not 100% sure on that. All different year xj's have their quirks some better than others like the 0331 head thats prone to crack if not properly maintained on the 00-01's. I drive a 98 for my dd and have a 01 for backup no major troubles with either,tons of research out there for mods and upgrades and plenty of aftermarket parts. I wish you luck with you new rig it looks pretty clean.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #5 of 6 Old 05-25-2013, 10:56 AM
dmill89
1995 XJ Cherokee
Nice, looks like it could use some new rocker panels though (easy fix). As others have said 98-99s are often considered the "best" years, though any 91-99 XJ is pretty good reliability wise (even 00-01s aren't too bad as long as you don't overheat them and maintain the cooling system).
dmill89 is offline
post #6 of 6 Old 05-25-2013, 12:53 PM
XJ99XJ
1995 XJ Cherokee
Nice xj. Always wanted a 2dr
--1999 Cherokee Sport 2" Lift 30" rubber
---1995 Cherokee Sport 4.5" 32" rubber
XJ99XJ is offline
