Opinions? $200 labor for U-Joint R2 - JeepForum.com
post #1 of 6 Old 03-19-2012, 10:48 AM Thread Starter
Flash1225
My 96 XJ needs new front U-Joints. I cannot do the labor myself. I was quoted by a friend at $200 labor to do the job.
Is this a fair quote? Or am I getting ripped off?
Thanks...
Flash1225 is offline
post #2 of 6 Old 03-19-2012, 10:53 AM
bob6987
axel or drive shaft u-joints?
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #3 of 6 Old 03-19-2012, 11:01 AM Thread Starter
Flash1225
Sorry....Front axle U-Joints.
post #4 of 6 Old 03-19-2012, 11:13 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Apparently not a good friend. I have done D30 u-joints for beer and pizza. To me, $200 is a bit much.
CJ7-Tim is offline
post #5 of 6 Old 03-19-2012, 11:18 AM
bob6987
its not a bad price...its about a 2-3 hour job.
need to remove tires (5 lugs), brakes (2 bolts), bearing hubs (3 bolts)...
The hardest part is getting the hubs out if it has never been done before. replacing my hubs the first time to quite a bit of work...
The next summer i replaced the ball joints and figured i would do the u-joints at the same time. Second time getting the hubs out was easy since i users a good amount of anti-seize on them.
i had napa replace the u-joints with the axels still attached to the hubs for $15 each...
2012 JKU
bob6987 is offline
post #6 of 6 Old 03-19-2012, 12:02 PM Thread Starter
Flash1225
Ok....Great info. Thank you!
Rockers for Labor Day Diamond-x XJ Cherokee Technical Forum 29 11-20-2014 05:48 PM
U-joint Ear was not seated in the front yoke today...should I replace the U-joint? gistecknician XJ Cherokee Technical Forum 1 01-04-2010 10:41 PM
AW4 to AW4 swap labor? jeepercreeperXJ XJ Cherokee Technical Forum 2 01-04-2007 11:57 PM
Need opinions on ball joint replacement... mission-inc XJ Cherokee Technical Forum 5 07-08-2004 12:17 AM
How much will the labor be? fourlow XJ Cherokee Technical Forum 12 02-24-2004 11:51 AM
