Notch Customs Fender Flares - Page 2 - JeepForum.com
post #16 of 22 Old 12-06-2013, 03:27 AM
Timo_90xj
Timo_90xj's Avatar
In other words, the flares are tough, but the mounting system isn't
Iäm wondering if you could add some sort of plating (sheetmetal spot- welded to the body) under the flares to prevent them from ripping through the body/ doors? I know it's a lot of work, but we all know that just the thin sheetmetal with self-tappers won't work on serious stuff.
I guess Notch customs has built these to look good and mount easily(no need to remove door panels or trim panels in the rear to install some sort of stock- style mounting strips). So, as always with aftermarket products, there's a catch and things could be improved..
***Under construction***
Timo_90xj is offline
post #17 of 22 Old 12-06-2013, 03:52 AM
sAe23
1995 XJ Cherokee
I would have liked to see him bash the flair against the ground like it was a hammer, but hitting it with the second sledge hammer was pretty impressive.
Too bad I just don't like the looks... too boxy / bulky / inelegant (Not that I could design a better one...).
sAe23 is offline
post #18 of 22 Old 12-06-2013, 10:22 AM
GetLifted
THIS
Is why I would never use fiberglass. Could care less about some "tough looking video". For the cost of these flares, a company could paint match carbon fiber and still churn a good profit. I would never consider anything fiberglass except speaker enclosures or I/O powerboats.
GetLifted is offline
post #19 of 22 Old 12-06-2013, 04:51 PM
ibjeepin95
Bushwackers are supposed to be strong too, and they are plastic. I've seen them literally explode once when leaned up against a rock. I'd hate to see fiberglass.
ibjeepin95 is offline
post #20 of 22 Old 12-06-2013, 06:01 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
I run them
They were free
They are invisible
They are indestructible
1990JEEPXJ is offline
post #21 of 22 Old 12-13-2013, 11:18 PM
robswampthing
You do have to remove all the interior trim in the rear to install them, and their is quite a bit of work involved, i have an install thread detailing it here.
http://www.jeepforum.com/forum/f11/n...lares-1607841/
2000 LIMITED, 4.6 stroker, 5", 35x12.5 kevlars, Allied beadlocks. (sold)
May 2014 COTM
2013 10th anniversary rubicon
ANNICON BUILD
robswampthing is offline
post #22 of 22 Old 12-13-2013, 11:37 PM
robswampthing
also for the record like i stated before, the flare itself, is super strong so far, and i have knocked it off trees when i slid down some sloppy leaves into the flare against a tree, i broke one of the bolts, but the flare itself shows no damage. Just paint scratched
May 2014 COTM
ANNICON BUILD
