Not sure where to start - JeepForum.com
post #1 of 3 Old 09-10-2013, 07:59 PM Thread Starter
djordan6319
I have a few things that need replaced on my XJ but not sure where to start . It is a 2001 with a 5.5 rubicon short arm lift with sway bar disconnects sitting on 33x12.50x15 MK2's..Here is what i am going to replace and why i am replacing the parts...
upper and lower control arm bushings (bushings are shot lots of popping noise)
sway bar bushings and disconnect bushings (all bushings are dry rotted and lots of movement in end links and sway bar)
upper ball joints (ball joints are good but my camber is out so i need adjustable ball joints)
wheel hub (passenger side wheel bearing is starting to make noise)
all tie rod ends (all seem to be ok just a lot of wear and tear on them)
Thanks for you advice
djordan6319 is offline
post #2 of 3 Old 09-11-2013, 08:12 PM
Muddy97Cherokee
1997 XJ Cherokee
I would start at all the mechanical problems. When you do the hub, also do the ball joints and the TRE's. Those are all easily capable in 1 day. In fact, the cracking/popping noise you here might be your hub.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #3 of 3 Old 09-12-2013, 10:58 AM Thread Starter
djordan6319
Thanks for the advice Muddy.....I am going to buy all new parts and rebuild the front and rear suspension so all the TRE's will be replaced as well as ball joints ect. The reason i didn't know where to start with this is all the ball joints TRE's wheel hubs ect are all still in good shape (not needing replaced) .....as far as the popping noise it is my control arm I had it on a lift looking at the control arms and the bushing is gone the control arm just slides from side to side
