noob xj build/ project - JeepForum.com
post #1 of 62 Old 04-08-2010, 08:58 PM Thread Starter
kirbWJ
1994 XJ Cherokee
heres my 94 xj, 2 door, 5 speed, 4.0L, command-trac, 120,xxx miles. JUST GOT IT FOR $500!!!!
and my illegal exhaust system... love california
kirbWJ is offline
post #2 of 62 Old 04-08-2010, 08:59 PM Thread Starter
kirbWJ
1994 XJ Cherokee
damn tinypic.com, sorry about the HUGE pics
kirbWJ is offline
post #3 of 62 Old 04-08-2010, 09:13 PM
N2OJeep
Junior Member
what are your plans for it?
N2OJeep is offline
post #4 of 62 Old 04-08-2010, 09:34 PM
BlackWhiteXJ
hah those tires look like they should be on a tractor man. i love the color though
BlackWhiteXJ is offline
post #5 of 62 Old 04-08-2010, 10:03 PM Thread Starter
kirbWJ
1994 XJ Cherokee
its gonna be my trail rig. i know it wont pass smog so im just gonna get an ohv pass... possibilities are endless. probably gonna go with a low COG setup, but i barely know anything about vehicles (one of the reasons i bought this rig). i was thinking a 4.5" from rough country (start with short arm), chop it, cage it, break it, and have a whole lot of fun! haha
kirbWJ is offline
post #6 of 62 Old 04-08-2010, 10:49 PM Thread Starter
kirbWJ
1994 XJ Cherokee
oh, and its an old forest service rig. im the 3rd owner!
kirbWJ is offline
post #7 of 62 Old 04-09-2010, 06:52 PM Thread Starter
kirbWJ
1994 XJ Cherokee
today i put a new battery in it, got all the electrical connections "cinched down" properly, next ill climb under it and get the support for my glasspack on, full tune up and fluid changes, and rip the interior out (old and moldy- literally). ANYONE HAVE ANY SUGGESTIONS? i need some input here!!!!! it shakes a lot driving down the road, what should i look for first (besides having non-radial tsl swampers)?
kirbWJ is offline
post #8 of 62 Old 04-09-2010, 07:23 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The tires are likely the biggest problem contributing to the shaking. I would pull the carpet and spray the inside with u-pol raptor liner, or roll on some monstaliner. I would also run a tail pipe from the muffler on to the rear to lose some of the noise. You will most likely have to put some decent tires on it to see if it shakes without the swampers, if it does the trac-bar bushings, control arm bushings, tierod ends and balljoints would be the most common causes for the shakes. Looks like a fun project enjoy it!
xjfever is offline
post #9 of 62 Old 04-09-2010, 11:16 PM Thread Starter
kirbWJ
1994 XJ Cherokee
ill throw some 235 ATs i have on there and see if that helps. what do i want to look for when i inspect my control arm and trac bar bushings, tie rod ends, and ball joints? im eighteen and trying to learn, so please bare with me!
kirbWJ is offline
post #10 of 62 Old 04-09-2010, 11:42 PM Thread Starter
kirbWJ
1994 XJ Cherokee
and i just found out that my XJ has the chrysler 8.25 rear! STOKED!!!!!! this deal seems to be getting better and better!
kirbWJ is offline
post #11 of 62 Old 04-10-2010, 05:12 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Check to make sure the bushings aren't cracked/dry rotted, and that the bushings are tight and not sloppy. Have someone turn the wheels back and forth while you lay under the front and watch the trac-bar and tierod ends. If the trac-bar moves around inside the mount the bushings are shot, same for the tierod ends, if the tierod moves a bit before the knuckles move you have play in the ends and need to replace them. For the balljoints jack the wheels up and place a prybar under the tire, then lift it up and down and see if there is movement or if it is tight.
xjfever is offline
post #12 of 62 Old 04-10-2010, 10:15 PM
NotDirtyEnough
at least the tires got some good meat still good buy for the price have fun with it
My Build Thread
NotDirtyEnough is offline
post #13 of 62 Old 04-10-2010, 10:53 PM
Curt41
Rather appropriate because a lot of people, myself included, consider the 4.0 basically a tractor motor.
Curtis
Check out my build thread
Survivalist Jeep #6
Rusty's 3in Full leaf pack, JKS quicker discos, rear sway bar gone, Carr light bar with 4 KC 6x9's, C4x4 Tow Hooks, Flowmaster Super 44 Off Road Muffler, 31x10.50 Goodyear Dura-Tracs
Looking for a set of pre-96 XJ front bumper endcaps
Curt41 is offline
post #14 of 62 Old 04-11-2010, 12:48 AM Thread Starter
kirbWJ
1994 XJ Cherokee
yea, i agree... the 4.0 should be an option for john deere!
kirbWJ is offline
post #15 of 62 Old 05-03-2010, 11:43 PM Thread Starter
kirbWJ
1994 XJ Cherokee
been a while since i posted last on this thread, heres where my XJ is sittin now!
kirbWJ is offline
96' sport build project gijazbo XJ Cherokee Technical Forum 21 11-23-2012 10:10 AM
Project Rosco Build thread. Mud_Pig XJ Cherokee Technical Forum 47 04-15-2011 02:41 PM
Project Bruiser - My 2000 XJ Build XJ2000 XJ Cherokee Technical Forum 124 02-08-2011 12:04 PM
Project not sure: a Non Build Thread Fiend101 XJ/MJ Cherokee Non-Technical Forum 18 07-05-2009 06:54 AM
RHD xj build. project postal. thenoblesock XJ Cherokee Technical Forum 66 05-05-2009 03:49 PM
