No crank/start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > No crank/start
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Clayton Off Road JK Short Arm Suspension Kits~Artec JK 1 TON SWAP~
Unread 08-26-2014, 10:21 AM   #1
bessyboy
Recently I put in a new radio in the XJ. After installing it I realized I left the key in the on position and it must have drained my battery. At first it cranked and would start but you had to give it gas to keep it running. Now it's not starting at all. I checked all fuses and now I'm stuck
And to add, I've had it on a battery tender for awhile. Also tried starting it on "start mode" and still nothing
-2001 WJ Limited, 4.7L V8, Thrush Glasspack muffler dumped before axle(no tailpipe), Spectra CAI,
Rusty's 2" BB
bessyboy is offline   Reply With Quote
Unread 08-26-2014, 11:06 AM   #2
bessyboy
Another update, I just kept trying to start it by turning the key all the way off and on and it finally started. But I shut it off and tried starting it agin and nothing. Would this be the ignition switch?
Rusty's 2" BB
Unread 09-04-2014, 02:35 AM   #3
88cherokeee
1988 XJ Cherokee
MAP sensor? that thingy from the air box to the intake. you said fuses how about relays?
88cherokeee is offline   Reply With Quote
