no buS???? - JeepForum.com
post #1 of 6 Old 08-14-2010, 12:11 AM Thread Starter
Adrian007
no buS????
Ok heres what happened. 99 Cherokee. I was driving and my air bag light came on, then all my gauges died and my check engine light came on. Then the mileage meter changed from miles to saying "no buS". After a while it went away. WTF
Anyone have this happen and know what caused this and how it can be fixed?
Adrian007 is offline
post #2 of 6 Old 08-14-2010, 01:11 AM
XJcruiser
Sure did....
http://www.jeepforum.com/forum/f11/no-bus-huh-705347/
Hasn't happened since though!
XJcruiser is offline
post #3 of 6 Old 08-14-2010, 07:34 AM Thread Starter
Adrian007
Thanks man. It didnt say in there, but do you think it could have been caused from welding on the jeep? Mine doesnt shut off or anything, its just the gauges, so Im pretty sure its not the CPS.
post #4 of 6 Old 08-14-2010, 01:27 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you get NO-BUS and the engine continues to run, it's most likely the instrument cluster. The plug on the backside gets corroded.
As long as your ground clamp is close to you work area, welding has no effect on the Jeep.
CJ7-Tim is offline
post #5 of 6 Old 08-17-2010, 02:49 AM
franknstn_cj5
X2, from a no buS survivor. It's just a loose connection out back. Whenever mine would come on in my old TJ I just hit the top of the cluster, and that always worked
Orrrrr you could be not as lazy as I and take it out to check those connections. Either way.
franknstn_cj5 is offline
post #6 of 6 Old 08-17-2010, 05:39 AM
Kevin108
Search is guten http://www.jeepforum.com/forum/f11/j...no-bus-890582/
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
cherokee , electrical issue , gauge cluster , mileage
