-   XJ/MJ Cherokee Non-Technical Forum (http://www.jeepforum.com/forum/f177/)
-   -   New to xj's (http://www.jeepforum.com/forum/f177/new-xjs-1566581/)
93jeepREDSOX 08-24-2013 04:31 PM
New to xj's
2 Attachment(s)
Hey guys, i have been on this forum for a while, but over in the yj forums. Well i wrecked the yj so as i build it back up i decided to pick up an xj for dd purposes. So hopefully i got fair deal, its a 96, 4.0, 5sp, with what i have been told is a 3" rusty's lift. Only has 126k and has new water pump, thermostat, master and slave cylinder, got it for $2400. Needs new tires and as i figured out on the ride home, has some death wobble. I have researched some about the death wobble which is pretty much replace anything up front that is loose or looks worn. So I have ordered new ball joints, upper and lower, tie rod ends, and a steering stabilizer. So any suggestions of anything else that i should look at to cure the death wobble please feel free to throw out suggestions.
93jeepREDSOX 09-01-2013 08:42 AM
So i think i figured out my death wobble problem, i had the rustys steering "upgrade" and a couple of the tie rod ends were shot. So instead of trying to deal with rustys and get the replacement parts i just went ahead and ordered a zj tie rod and got a stock drag link. So hopefully that solves that problem. Also picked up a set of used 31s and bought some mickey thompson classic rims from my friend.
RustysOffroad 09-05-2013 02:39 PM
You could get the replacement parts from almost anywhere. :)
The replacement part # for the tie-rod ends are:
#52005739R / MOOG part # ES3096R (Right Hand)
#52005739L / MOOG part # ES3096L (Left Hand).
AKIQPilot 09-05-2013 11:05 PM
Good looking XJ. Welcome to the forum. Look real close at both ends of the track bar. The axle end bushing wears out pretty easily it seems.
93jeepREDSOX 09-10-2013 10:09 AM
Yea i think i may just order a new one next month with a steering box brace just to be safe. I put on the new drag link and tie rod and drove it around, got up to 45-50 and it seemed better. Needs and alignment though cause the steering wheel is off and the tires are out of alignment. Unless there is a way i can do it myself or with a friend.
All of the tie rods on the rustys "upgraded" steering were toast though so i am hoping they were the main cause. Nothing else seems to move if i give it a good shake with my hand.
The time now is 08:33 PM.
